5th Sep 2013, 11:07 am | #1 |
Dismantling a "Microphone, Hand No. 8". . .
. . . as used on a range of WWII-era Army radios: my question being - on the bottom of these, where the cable exits the handle, is the bush the cable comes out through supposed to unscrew? It has 2 flats on it which would support the idea that it unscrews but on mine it appears this bush is glued in rather firmly.
--G6Tanuki |
5th Sep 2013, 12:55 pm | #2 |
Re: Dismantling a "Microphone, Hand No. 8". . .
Yup - they unscrew.
5th Sep 2013, 3:37 pm | #3 |
5th Sep 2013, 3:52 pm | #4 |
If you break it - I probably have a spare somewhere - though finding it will be the biggest challenge at the moment.
Tim |
5th Sep 2013, 5:58 pm | #5 | |
[The mic is destined to feed - through a suitable transformer - a single-ended 6L6 which should provide enough audio to modulate another 6L6 serving as xtal-oscillator/PA: I'm doing a budget re-creation of the RCA AVT-15 aircraft transmitter from the 1930s]. |
5th Sep 2013, 9:45 pm | #6 |
Drop a little liquid paraffin wax on it, works great on these sort of threads. After removing wipe off with paper towel.
Glo |
6th Sep 2013, 9:22 am | #7 | |
If thay doesn't help I will try some warmed paraffin-wax to see if that will soften things enough to let me unscrew it. --G6Tanuki |
6th Sep 2013, 12:07 pm | #8 |
I'd hazard a guess at Shellac or some sort of varnish if it's original MOD.
22nd Sep 2013, 1:35 pm | #9 |
Here is a thumbnail of the cord grip of the Hand No 7 microphone.
unscrewed to show the length. Amazingly I did find it. Finding the others, Nos 3, and 8, that are here will be a bother.
Steve Dow VE7ASO |
23rd Sep 2013, 9:23 am | #10 |
Thanks Steve. My threaded-bit is still soaking in the water, the glue sahowing no signs of dissolving.
I am thinking of trying to soak it in Meths next. --G6Tanuki |
23rd Sep 2013, 2:06 pm | #11 |
I seem to recollect, when I was at an electronics company back in the 80’s, they used to encapsulate everything in epoxy resin, and a well know brand of a fizzy drink C*ca-c*la used to soften the material.
And if it doesn’t work you could always have a refreshing drink Paul. |
23rd Sep 2013, 4:25 pm | #12 |
Hadn't thought of using said fizzy-drink for this purpose; I don't normally have the stuff in the house but am prepared to buy a can of "Value" Cola from somewhere to see whether it works.
--G6Tanuki. |
20th Oct 2013, 9:38 am | #13 |
Result! After a month of soaking in methylated spirit I put an open-ended spanner on nthe flats, and pushed.
There was a worrying crack - then it unscrewed. You can see the remains of the brownish glue still in the threads. |
