| Vintage Test Gear and Workshop Equipment For discussions about vintage test gear and workshop equipment such as coil winders. |
#1 |
hi Folks
I have a Weir 413 0-30v PSU with a fault. I found some info on this thread https://www.vintage-radio.net/forum/showthread.php?t=56278 but the circuit diagram here, though having some similarities to my unit, is not the same - mine is all discretes, no op amps. I wonder if anyone has any other info on these? I have two - the 413D (-15 0 +15v) works, but the 413 (0 30v) does not, so info on the latter would be especially useful. Thanks Mark |
#2 |
That peculiar graphical representation of pushbutton combinations is something I've seen before. It's on a Marconi supply of about the same size at work.
It's earlier than those Weir units, but very similar. Don't have any info on it, just a supply bought in an ex-government (think of it as a tax refund) lot. I wonder if Weir took over the designs from Marconi, and later modernised them? If so, you might find info on your unit by searching for Marconi Instruments. It's a useful low noise supply. David
#3 |
Look out for the connections between the terminal posts and the internal wiring.
They blow the currant limit transistor to open circuit ![]() It is a pain getting access to the terminal posts for a repair too. |
#4 |
I did not get any further than you when looking for the circuit diagram.
#5 |
Marconi Instruments originally badge-engineered them as TF2153, TF2154 and TF2155 and I guess when Weir updated the designs MI did not continue with them. I've got circuits and will scan them when I've got time but you might find something's already out there.
Regards, Richard, BVWS member |
#6 |
It is the "D" models that we can't find the circuit diagrams for. They may well be later than the Marconi models. They are the ones with center zero outputs for OP amps and so on.
I had to work without a manual in order to fix mine. |
#7 |
Richard - I'd very much appreciate that. I've found versions on the web for sale, so a scan would obviously help me out a lot. No rush!
Thanks Mark |
#8 |
...well, I did the sensible thing and went and spoke to the electrical technician in the university building outside of which I pulled my duff PSU from the skip.
A rather low-res scan is attached of the correct manual and circuit diagrams. If you really need a better one I have a good photocopy and may be able to think of a way to get one to you. Mods - I don't think I can change the thread title. If it were possible to change it to 'Weir 403 413 423 circuit diagram', it would reflect better the information now to be found within! cheers Mark |
#9 |
I've saved a copy too to help dissuade Murphy from jinxing the one at work
Thanks, David
#10 |
Cheers for the scan Mark.
The scan is good and clear enough for information. The "D" option part was missing from the scan I had. |
#11 |
The Marconi version is very similar but my handbook has a sheet of component changes up to 1978 which may be of use. Sorry about the quality.
#12 |
Oops.
The fault on my unit meant it worked OK from 0v to about 1/3 FSD, and then shot off to the full supply rail. So I got all sorts of fancy ideas about the control circuit and probed around for ages, writing down voltages here there and everywhere. And then I checked the 50K main pot, which was o/c about 1/3 of the way through its travel. ![]() I had a huge 10 turn 100k pot in the box - guess I can put 100K in // with it. So now it works, with super-fancy hi-res volt setting capabilities... |
