Old 14th Jun 2006, 9:27 am   #61
Sideband
Sideband's Avatar
Default Re: TV22 Restoration
Originally Posted by Jarl Ayari
I thought the pins on this were :
Grid, Heater, Heater, Kathode, Anode1, and EHT Cap?
Hi Jarl. It depends how old you are! When I were a lad we always called it A1 (first anode). Now it is more commonly known as G2. Strangely enough, if I am working on a colour set I call it G2 but when working on old sets, I call it A1 .
Rich.
'Can we have everything turned up louder than everything else'? Ian Gillan...Deep Purple
Sideband is online now
Old 14th Jun 2006, 10:00 am   #62
Courtney Louise
Courtney Louise's Avatar
Lol, well as this is my first TV I am just going on what the diagram and what others call it so A1 it is.
Well I still have that odd fault and need the meter on to get a full frame pic now. I have just finished recapping the IF panel and changing some very black resistors that were very very low in value. Mainly the trio of 470r resistors in the middle of the chassis.
Andi
Life is long, life is short, both of these a daunting thought.
Last edited by Mike Phelan; 14th Dec 2007 at 9:30 am. Reason: Unnecessary capitals
Courtney Louise is offline
Old 14th Jun 2006, 12:41 pm   #63
Ed_Dinning
Hi Andi, temporarily connect a 2M2 from the tube in place of the meter (or whatever the equivalent meter resistance is).
This sounds almost like the case of old radios that would burst into life for a min or so when the grid was probed with a meter as the grid leak had gone O/C and the grid was charging up with no leakage path.
Ed
Ed_Dinning is offline
Old 14th Jun 2006, 2:52 pm   #64
Courtney Louise
Thanks Ed,
Will try that tonight. I have also now finished the recapping of the IF stage so tonight I might even get me a test card on it...
Wish me luck
Andi
Old 14th Jun 2006, 6:12 pm   #65
Courtney Louise
Hi Ed and everyone else...
Well I finished recapping my IF stage and connected the ht back up to it and voila I didn't need the meter across the A1 anymore and the HT came up to 200v on the A1.
Now the problem is I only have my Aurora as a signal and I get nothing out of the TV but a blank raster....
How on earth do I fault find an IF stage with no test equipment like that?
Andi
Old 14th Jun 2006, 6:17 pm   #66
Courtney Louise
Am I right in thinking that I could put a line level audio signal onto one of the pins of the chassis connector to feed the grid of the audio amp?
Is there anyway I could feed a video signal in from My aurora after the IF and tuner stages just to make sure it will display a picture?
What if I fed a composite video signal into pin 6 of the inter chassis connector? and an audio feed into pin 3?
Andi
Old 14th Jun 2006, 6:39 pm   #67
Courtney Louise
OK, after looking at the circuit I know I can't just feed signals on to any of these pins, as there is a very substantial voltage on them, and not what it should be, I don't think...
Going to do some metering...
Old 14th Jun 2006, 7:30 pm   #68
evingar
evingar's Avatar
ok after looking at the circuit I know I cant just feed signals onto any of these pins as there is a very substancial voltage on them. and not what should be I dont think...
I know its been mentioned before and I'm not saying it can't be fixed with just a meter but IMHO a 'scope would **really** make your life easier for fault finding signal and video circuitry. Is there any way you can get a X10 probe for your ‘scope? It would be well worth the small expenditure, especially if you plan on doing more TV’s (and I bet you will once you get this one going) eBay usually has some “floating around", I know Jim has offered one. As a last resort Farnell have low bandwidth ones for a few quid: -
http://uk.farnell.com/jsp/endecaSear...=4284033&N=401
Anyway, sound like progress is being made, well done and all the best
Chris
evingar is online now
Old 14th Jun 2006, 8:47 pm   #69
Courtney Louise
I am very unsure about using my scope on valve stuff. I don't want to fry anything... Also the trader sheet is very limited, no information about what to expect scope-wise and I have no clue what I am actually looking for...
Old 14th Jun 2006, 9:45 pm   #70
Ed_Dinning
Hi Andi, this is where running an AC/DC tele through an isolating transformer becomes useful as there is no "common mode" voltage on the chassis that can zap the test equipment when it's ground is commoned to the test equipment ground.
There are "dirty" techniques you can use but not worth trying if you are unsure of what you are doing.
The signal lead is not so much of a problem. A suitable value capacitor for the frequency of the signal being applied, and of a suitable working voltage will block the DC and get some sort of signal through. Getting the levels right and a good picture is a different matter!
HTH Ed
Old 14th Jun 2006, 10:28 pm   #71
Sideband
Sideband's Avatar
Andi.
Before assuming there is a front-end fault, are you sure your standards converter is producing a signal on the right channel for your TV ? I'm just thinking about London and Birmingham versions.....just a thought.
Rich.
Old 14th Jun 2006, 10:44 pm   #72
Courtney Louise
Hi Rich,
The Aurora is a 13 channel converter so I set it to channel 3
The TV22 supports channels 1 to 5 so I guessed 3 should appear somewhere between zero and full adjustment.
I need to get an isolating transformer...
I have noticed that my main HT rail is 15v high...
Andi
Old 14th Jun 2006, 10:55 pm   #73
Sideband
Sideband's Avatar
Ah!! Didn't know the Aurora was switchable !
Don't worry about the HT being 15 volts high. Mains variations can cause this.
Rich.
Old 15th Jun 2006, 9:25 pm   #74
Courtney Louise
OK Here we go, a few pics of what's been done so far...
Thanks for all the interest so far
These are the 1st 4 pictures I would like to share,
The first is how I found it. It was on ebay in Stratford which isn't far and I managed to negotiate a deal if I went round there and then, the asking price was 75 but I got him down to 60 because the tube was in 2 halves (see 5th picture).....
The sawdust is all that is left of the left wooden support bar from the kind woodworm, the right one although not looking bad was just as bad...
Pics 3 and 4, this is how the case looks now, I havent finished the polishing yet and also havent tried Nick's lolly stick idea (apologies if it was someone else but I am terrible without looking back) as I thought it was much more important to get it working, than making it pretty.
Thanks
Andi
ID:	4189   Click image for larger version
Name:	100_1739 (Large).JPG
ID:	4190   Click image for larger version
Name:	100_1755 (Medium).JPG
ID:	4191   Click image for larger version
Name:	100_1756 (Medium).JPG
ID:	4192   Click image for larger version
Name:	100_1763 (Medium).JPG
Old 15th Jun 2006, 9:32 pm   #75
Courtney Louise
Another 5
There are probably somewhere like 100 pics so far, of the various strip and rebuild. I always take plenty when wanting to remove a complete tag board like the one on this that holds the power resistors and frame decoupling caps, and also the frame oscillator transformer.
Hope they are ok. Like I said I am planning a website to do with the whole TV22 experience; just like the day in the life we used to read in Television. Was is Les Lawry Johns?
Andi
PS I know the .75uf cap isn't soldered very neatly but this is a 'get it working' job and will tidy up things like that once it's finished...
Name:	100_1819 (Medium).JPG
ID:	4193   Click image for larger version
Name:	100_1791 (Large).JPG
ID:	4194   Click image for larger version
Name:	100_1827 (Medium).JPG
ID:	4195   Click image for larger version
Name:	100_1675 (Medium).JPG
ID:	4196   Click image for larger version
Name:	100_1817 (Medium).JPG
Old 15th Jun 2006, 9:36 pm   #76
Brian R Pateman
Brian R Pateman's Avatar
Another 5
Hope they are ok. Like I said I am planning a website to do with the whole TV22 experience just like the day in the life we used to read in Television. Was is Les Lawry Johns?
Andi
Yes it was!
Les was always worth reading, a wonderful sense of humour and a d d good engineer.
I consider myself lucky to have known him.
Regards,
Brian
Forum moderator.
Brian R Pateman is offline
Old 15th Jun 2006, 9:43 pm   #77
Courtney Louise
I used to read 'Television' just because of that column when I was in school as we (4 electronics club nutters who used to go round the skips of Multibroadcast, etc for boards) petitioned the library to add it to their periodicals.
Old 19th Jun 2006, 8:31 pm   #78
Courtney Louise
Hi guys.
OK This is a long shot but if my friend and I are correct in our assumptions we think we know now why I don't have a picture on the TV when I attach the antenna.
This IF stage when I got it had a band III converter fitted which I have removed. The thing is... What modifications had to be done to the IF panel to fit the band III converter to start with?
I need to reverse whatever mods were made.
Regards
Andi
Old 19th Jun 2006, 9:15 pm   #79
Courtney Louise
Hi guys, me again, I bet most of you are sick of this by now hahaha
OK I have found a missing contrast wire that I have replaced but are there any other mods made to the IF panel to allow the band III converter to work?
Thanks
Andi
Old 19th Jun 2006, 9:18 pm   #80
ppppenguin
ppppenguin's Avatar
Don't worry about it. You've been climbing a pretty steep learning curve and we are more than happy to help anyone who's enthusiastic enough to have a go.
ppppenguin is offline
