Old 29th Apr 2012, 11:58 am   #1
M0FYA Andy
Default Paxolin Disks
Has anybody got any hints or tips on how to accurately cut disks from thin paxolin, accurately circular with smooth edges?
I have a dozen or more Colvern wirewound potentiometers with bakelite bodies which should have a paxolin disk back glued in place into a rebate in the bakelite. Unfortunately over time the glue has failed and the backs have gone AWOL.
Depending on the power rating the disks need to be from about 1.25 to 1.75 inches in diameter.
Any ideas welcome, please!
Many thanks,
Andy
M0FYA Andy is online now
Old 29th Apr 2012, 2:23 pm   #2
TrevorG3VLF
TrevorG3VLF's Avatar
Default Re: Paxolin Disks
Not easy, I do not see how this can be punched without a press to locate the punches.
The way I would try is to cut out a disc oversize, place it between two wooden discs and place in my wood turning lathe attachment with a large end load and turn to the required diameter.
TrevorG3VLF is offline
Old 29th Apr 2012, 2:24 pm   #3
peteratnith
No Longer a Member
Hi Andy,
Drill a hole for a 4 or 5 mm nut and bolt in a piece cut roughly to size then "turn" it to size with a file in a power drill. Then glue up the hole. A neat way is to cover one side of the hole with tape and put glue in the other side. I.ve used double sided tape to hold a disc to the face of a lathe chuck. You could do that on a drill, with care.
Peter
peteratnith is offline
Old 29th Apr 2012, 2:54 pm   #4
M0FYA Andy
Yes, I can see ways of doing it by starting with a hole in the middle, but it seems rather counter-productive to make a hole which then must be filled, and difficult to achieve neatly!
I imagine when these were made the backs were churned out by the thousand in minutes using a punch made for the job.
Andy
Old 29th Apr 2012, 4:48 pm   #5
Herald1360
Herald1360's Avatar
If the paxolin is thin enough, won't scissors do the job?
Alternatively, if you clamp the paxolin sheet to a piece of wood you should be able to use a hole saw in a bench drill set up so that the central drill bit doesn't stick out of the saw. Maybe use an old pot spindle instead?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 29th Apr 2012, 4:57 pm   #6
M0FYA Andy
I tried cutting a piece with scissors, but I just wasn't happy with the accuracy of the end result!
Old 30th Apr 2012, 6:02 pm   #7
crackle
crackle's Avatar
Hot glue is strong enough to hold the paxolin to a round block of wood or metal bolted to a countersunk bolt used as a spindle. You can then turn this in an electric drill and file round, best to use a tool rest to help hold the file (tool) I used my drill stand on its side with a block of 3x3 timber as the tool rest. Do be careful though with fingers and use goggles, and don’t allow it to become too warm.
I now have a small lathe so it is a bit easier and not so dangerous.
When you have finished just warm up the disk and slide the paxolin off.
Mike
PS. you could use an old car engine valve to glue the paxolin to.
crackle is offline
Old 30th Apr 2012, 6:46 pm   #8
GrimJosef
I recently did exactly this to make a new back for one of my Colvern pots. I marked the circle I wanted on the paxolin using a compass, rough-cut it out with a hacksaw and hand-filed it circular. If had wanted to do 12 it would probably have been worth making jigs and support pieces and/or drilling holes then filling them again and/or rooting out my hot-melt glue sticks. But to do just one took perhaps 15 mins with the compass, hacksaw and file and ended up a very neat precise fit (I kept checking the size against the actual pot as I was carrying out the job).
Cheers,
GJ
GrimJosef is online now
Old 30th Apr 2012, 7:10 pm   #9
fetteler
fetteler's Avatar
Make a plywood disc with a bolt through the centre to hold the paxolin whilst you turn it in a lathe (if you have one) or, as a previous poster has suggested, an electric drill can be used as a stand in. Stick the thin paxolin sheets to the plywood disc using double sided tape and off you go...
Steve.
Those who lack imagination cannot imagine what is lacking...
fetteler is offline
Old 30th Apr 2012, 7:14 pm   #10
DragonForce
I've long since had an idea for a tool that will do exactly what you're talking about. If I had access to a lathe I think I could easily make one.
The idea is simple - I'm sure most of you guys are familiar with the concept of a panel pin pusher? It's a spring loaded rod inside a tube that you load with a panel pin (small nail), and then push the plunger, and therefore the panel pin, into the job.
Ok - so imagine, the reverse. Instead of pushing a plunger that is inside the tube, the tube is pushed over the plunger - it is the tube itself that is sharp and acts as a cutter. The centre plunger being sharpened like a pencil (or centre punch) to allow for precision placement, the tube then slid down over the centre plunger to cut the work-piece. With a very light spring load, the centre punch wouldn't mark the surface of something like paxolin.
I want something like this to allow me to make small washers in polystyrene "plasticard" to allow me to fabricate my own home made coils. I see no reason why, anybody with a lathe and a little patience couldn't make such a thing. The tube can be sharpened like a saw-blade or honed like a chisel - so ling as it's quite thin and the centre plunger is a very good fit, I can't see how accuracy will be an issue either
DragonForce is offline
Old 1st May 2012, 8:58 am   #11
Tractorfan
Tractorfan's Avatar
Smile Re: Paxolin Disks
It might be worth putting an appeal in the "Wanted" section. I'm sure folk may have kept the discs that fell off the pots, or the scrap pots themselves. I know I had a few kicking around somewhere.
Just an idea.
Cheers, Pete
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 1st May 2012, 9:39 am   #12
M0FYA Andy
DragonForce, that sounds like an improved version of a 'wad punch' used to cut a hole in leather or similar, although usually it is the hole that is required rather than the disk. I agree that your concept should work if it is made.
Tractorfan, good idea!
Andy
Old 1st May 2012, 1:17 pm   #13
Station X
Station X's Avatar
Turn or file some metal discs to the correct diameter. Alternatively you may be able to find coins or washers of the correct size.
Clamp paxolin betwen the discs and file to the correct size.
Achieving alignment of the discs might be a problem. You could try glung then to the "jaws" of a 'G' clamp. The paxolin might be transparent enough to see through with a bright light behind it, then you'll be able to see both discs to align them.
Have a go with a couple of washers or coins first to see if the idea works for you.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
