#1 |
I'm trying to make a circuit using the components of a CFL (HV transistors, ferrite core, HV diodes, HV capacitors, etc) in order to obtain a 5V source to supply a TTL-made timer for a microwave oven. All circuit I have checked use two ferrite cores. I think it is posible to do it using just one core.
I need some help with the cicuit configuration (for the self oscilating circuit) and how many turns (approx.) should I coil in the ferrite core. The 5V circuit will demand 500mA. I want to rectify the 110 V AC line supply and using one of the capacitor of the CFL, obtain 150 V CD (non-regulated), and then the self-oscilating circuit with one independent secondary to obtain 5V using a single diode and a small capacitor. I've read that 40 kHz oscilation would be suitable for this purpose. It is now working with an iron core transformer and a 7805 (TO-3), but I want to change to ferrite core because the iron transformer and the 7805 get hot when they work for some time. Thanks in advance. Miguel PS: If there is a thread about this I apologise. Please redirect me to that thread. |
#2 |
This sounds dangerous, being in effect a DIY 'live chassis' circuit.
#3 |
No. My idea is to make an independent coil for the 5V circuit. This coil will be electrically isolated from the 150V circuit. The 150V circuit won't be ellectrically connected to anything but the line supply.
This is my idea (see attachment): |
#4 |
Designing a switch-mode off-line power supply is not a 5-minute job. With the constraints of using the bits from an existing unit (ie not allowing for blowups with no replacements allowed) it's almost impossible.
If you want a 5V 500mA supply, can you not go to a car boot sale (do they have them in Cuba)? Me, i'd use a small mains transformer, rectifier, capacitor, 7805. Yes, it may get warm. But, no RFI, easier to make, msafer, more reliable, etc wins every time! |
#5 |
My post crossed with the OP's...
Straight away, looking at the circuit, it won't work well. The transformer phasing is wrong - it's operating in the forward mode, with no output choke (so indeterminate peak current in the switching transistor) and there's no energy recovery winding. What happens to the energy stored in the core - or is it intended to resonate with the capacitor across the transistor? Dodgy... If you reverse the secondary wires, and rectify during the flyback period, most of the above is fixed. But then you'll have to either clamp the output voltage by a power Zener diode, to stop it rising if the load is removed, or find some way of controlling the primary-side to regulate it. I'd stop now! |
#6 | ||||
![]() Quote:
We do what we can, with whatever thing we have at hand. I don't have a transformer suitable for that purpose. It really get hot, and I need to change it. That's why I thought in the CFL. CFL are availables at assequible prices. Quote:
Thanks anyway. Last edited by Miguel Lopez; 16th Dec 2011 at 4:54 pm. Reason: add comments |
#7 |
Hi Miguel,
I admire your determination, but I'd start with something that was designed as a low voltage dc power supply. A mobile phone charger could be a good idea, one for charging through a USB port would be ideal as it should be rated at 5Vdc. Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
#8 |
I'd get a cell phone charger, those have to be readily available and cheap to you?
#9 |
Hi Miguel, if you are looking at simple SMPS designs then look at the applications on the Power Integrations website. These have plenty of design details as well as somer information on transformers. They normally use an integrated controller and mosfet in a TO220 package.
Ed |
#10 |
Thanks to glowinganode and mrmagnetophon
When I read your post I was with one of those chargers in my hands. I think that could be a good idea. I can reverse-engineer this charger and then I can change its parts by the components of a CFL, in order to obtain the milliamps that I require. It could take a lot of "trial and error" (making emphasis in error), but I think it could work. Sorry Ed, that would be nice but those integrated controllers are not available to me. Thanks for your cooperation. |
#11 |
How many milliamps are you trying to achieve?
The cell phone charger transformer should be good for up to 300mA and with a few capacitors and maybe a new bridge rectifier built from cfl parts should be able to handle up to 500mA for non-constant usage. -Chris |
#12 |
I need 500 mA for non-constant usage. The cell phone charger I've seen in Havana are only up to 100 mA.
#13 |
Looking for info in the web I found this diagram. I think I can mount it.
http://www.seekic.com/uploadfile/ic-...3302203978.gif Now I need to know how many turns must have each coil. I will measure the section area, and I hope all of you give some help in this matter. |
#14 |
Its surprising that your cell phone chargers are only 100mA, generally anything within the last 5-6 years will be at least 500mA to conform with the USB standard.
I guess things are very different in Cuba, but over here most people are falling over old phone chargers as they are everywhere. Can you get in-car (automobile) Cell phone chargers cheaply? they usually provide 5V at up to 500mA to 1000mA, and they will run from any voltage from 7 up to 24v, you could use any old transformer/charger with one of these. Dave. |
#15 |
Hi Dave.
Friend, I can assure you that you would be surprised about the things that happen in Cuba. They would be surrealistic for you. Don't try to understand them or your brain would burn out. The only thing I can tell you about that, is .....yes, there are those chargers which can deliver 500 to 1000mA, but they are out of my reach. Economic reasons. I have dismounted the CFL circuit I had, and then I will design the PCB to begin my "trial and error process". Anyway, I'll take a break during these days in order to spend some time with my family. Not everything has to be work and hobby. |
#16 | |
I found a description of how that circuit operates. It has several translation errors, but it's useful anyway.
When electrons move, things happen. There's nothing you can do that can't be done. |
