Reply
Old 1st Nov 2011, 10:20 am   #1
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Useful tuning scale and label scans etc
A Mullard MAS97 radio I have here temporarily came with a complete sheet of station ident labels for the preset station buttons.
I thought these could be useful for other members who own this set or similar sets, so have scanned them and attached them here. The ZIP file contains the full size scan at 300DPI, the image is smaller due to forum size restraints. Each ident is approx 16mm by 8mm.
Rather than just posting as a thread which can get lost, I thought a sticky thread where people can post other scans of tuning scales, labels, logos and other idents would be a useful resource. Please add whatever you have that could be useful for other restorers.
PLEASE DO NOT USE THIS THREAD TO REQUEST SCANS, JUST TO POST ONES YOU HAVE TO SHARE. THANKS.
Paul Stenning
Forum Admin/Owner and BVWS Committee Member
Paul Stenning is offline   Reply With Quote
Old 1st Nov 2011, 11:01 am   #2
Alistair D
Alistair D's Avatar
Default Re: Useful tuning scale and label scans etc
There are a number of dial scans here.
http://www.pasttimesradio.co.uk/dials/tuningdials.html
Al
Alistair D is offline   Reply With Quote
Old 15th Nov 2011, 9:41 pm   #3
greenstar
greenstar's Avatar
The backing has peeled off this HMV dial. About 1942. From a cabinet, alas, no innards.
Tony
Last edited by Darren-UK; 16th Nov 2011 at 1:25 am. Reason: Image flipped right way up.
greenstar is offline   Reply With Quote
Old 22nd Nov 2011, 8:01 pm   #4
ms660
ms660's Avatar
Artwork for Marconi CR300 logging scale dials, I posted some in the refinishing section the other day but in these ones I have updated the font specifications so as to be a closer match to the original dials, parameters for recreating the images in your own drawing program are given in each picture.
Lawrence.
ms660 is offline   Reply With Quote
Old 24th Nov 2011, 7:35 pm   #5
crackle
crackle's Avatar
Ferguson 208UL Original dial - Higher resolution available if any one wants it.
Name:	ferguson 208UL dial plate 2.jpg
crackle is offline   Reply With Quote
Old 24th Nov 2011, 8:00 pm   #6
crackle
crackle's Avatar
GEC BC5444L reconstructed dial - Higher resolution available if any one wants it.
Name:	GEC DIAL PLATE new font.jpg
Old 24th Nov 2011, 8:07 pm   #7
crackle
crackle's Avatar
Marconi 7207 Original dial - Higher resolution available if any one wants it.
Name:	marconi 7207 dial plate.jpg
Old 24th Nov 2011, 8:10 pm   #8
crackle
crackle's Avatar
Sobell 516 Original dial - Higher resolution available if any one wants it.
Name:	sobell516 dial b.jpg
Old 3rd Dec 2011, 3:51 am   #9
hilltopgrange
Some scale scans here
http://www.vcomp.co.uk/dials/dial_glass.htm
Russell
hilltopgrange is offline   Reply With Quote
Old 3rd Jan 2012, 7:44 am   #10
crackle
crackle's Avatar
KB FB10 Midget "Toaster" Original dial - Higher resolution available if any one wants it.
Old 11th Jan 2012, 10:00 pm   #11
crackle
crackle's Avatar
Ferranti 345 Original dial - Higher resolution available if any one wants it.
Old 12th Jan 2012, 11:29 pm   #12
ThePillenwerfer
ThePillenwerfer's Avatar
Bush DAC90a both raw and cleaned up. PM with an e-mail address for hi-res versions.
- Joe
Name:	DAC90a Dial - raw.jpg
ID:	61130   Click image for larger version
Name:	DAC90a Dial - Tarted.jpg
ID:	61131   Click image for larger version
Name:	Ivory Dial -raw.jpg
ID:	61132   Click image for larger version
Name:	Ivory Dial -Tickled.jpg
"Experts are only good at one thing: explaining why something will not work!"
ThePillenwerfer is offline   Reply With Quote
Old 12th Jan 2012, 11:31 pm   #13
ThePillenwerfer
Pilot T105 'Little Maestro.' PM with an e-mail address for hi-res version.
- Joe
Old 13th Jan 2012, 5:58 pm   #14
ThePillenwerfer
Pye R33. PM with an e-mail address for hi-res version.
- Joe
Old 15th Jan 2012, 2:29 pm   #15
ukcol
ukcol's Avatar
Decca TP75 tuning scale.
Colin M
Best Regards, Colin McLaughlin
BVWS Member
ukcol is offline   Reply With Quote
Old 15th Jan 2012, 10:00 pm   #16
crackle
crackle's Avatar
Cossor 501 Original dial - Higher resolution available if any one wants it.
Name:	cossor 501 dial 2jpg.jpg
Old 23rd Jan 2012, 1:39 pm   #17
ThePillenwerfer
Pye P75. PM with an e-mail address for hi-res version.
- Joe
Old 23rd Jan 2012, 5:57 pm   #18
ThePillenwerfer
OK, here's mine.
- Joe
Old 31st Jan 2012, 6:57 pm   #19
ThePillenwerfer
Bush VHF70.
Old 5th Feb 2012, 12:25 pm   #20
Station X
Station X's Avatar
Posts concerning image formats and compression moved to a new thread here:-
https://www.vintage-radio.net/forum/...ad.php?t=79556
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is offline   Reply With Quote
Reply
