25th Jun 2011, 10:25 pm | #1 |
Telonic 1205A sweep generator
Hi to all the group,
Some time ago I got a Telonic 1205A sweep generator, but it's without the manual, now my old one is too low in frequency for what I want to do, so I need the manual to study it a bit. Can someone help me to find it, or have one that can send me as a PDF? if possible also schematic. I've searched on the internet but found nothing. Thanks to all that will reply me and I wish you good day. Yours sincerely, Sergio T. |
26th Jun 2011, 3:22 pm | #2 |
Re: Telonic 1205A sweep generator
Ask WMEbill
Peter |
14th Jul 2011, 5:37 pm | #3 |
Thanks Peter (Chaparal)! Has Sergio T% (islington) seen the earlier thread. All I have is the 1204 /1234, covering 1-500 Mhz in one range, obtained by a VFO on 1000-1500 and a fixed oscillator on 1000Mhz, then an Amplifier to 500Mhz. I suspect the versions covering up to 1500Mhz in 3 ranges uses two VFOs, covering the 500-1000 and 1000 to 1500 Mhz ranges, and no amplifier. This was the arrangement in the very similar Wavetek 2000 series of sweeper. Bill m0wpn
14th Jul 2011, 6:44 pm | #4 |
I have a Telonic 1202A (0-120MHz) and info on that is also elusive.
19th Jul 2015, 12:18 pm | #5 |
I know this is rather old, but
http://www.schematicsunlimited.com/ have the Telonic 1205/A manual, plus lots of others. Not come across this site before. |
