23rd Feb 2011, 11:26 pm | #21 | |
Re: Making of an HT battery
17/6p in 1934 equates to £42.00 in 2011!! David (Neat idea to use the brass tubes for voltage tappings, rather like the grid bias batteries of yore). |
24th Feb 2011, 12:27 am | #22 |
How about the Voltokil 135?
Or maybe AA90?
24th Feb 2011, 2:27 pm | #23 |
Cover made...
24th Feb 2011, 3:11 pm | #24 |
Well done merlinmaxwell! You've made a really neat job of this.
As a newcomer to this forum, it is great to see that others enjoy making HT batteries as well! I have been a keen collector of battery operated sets for many years; it is great fun to be able to use them exactly as intended - fully portable! I have restored old B101, B107, B114, B126, B136 and B141 Ever Ready batteries by using chains of PP3s - the smaller HT batteries require them to be soldered together in a stack but in the larger batteries (B107 - Ever Ready Model N, B136 - Sky Queen and B141 - Sky Casket/ Captain/ Baronet) they can be joined simply by clipping them together using their own contacts to form a flat pack of ten batteries in two slightly staggered rows of 5 each. This way, you only need a single connector stud for each end! Several years ago, I built an Ever Ready 'Portable 56' HT battery for an Ekco B53 receiver. I employed the same methodology of using individual 1½ volt cells to deliver the 136½ volts required, however, as the Portable 56 was very large battery I had room to simply clip the cells into an array of 9 volt holders. I fitted a small chassis mounted fuseholder inside the battery along with a 100mA fuse for safety. Best wishes, Colin. |
24th Feb 2011, 7:39 pm | #25 |
BRILLIANT!
26th Feb 2011, 4:52 pm | #26 |
A quick flick of the AVO on the 12V tapping gave over 10A, assume it will give 10A S/C at 135V that gives an internal resistance of 13.5 ohms. For maximum power delivery Zo = Zi therefore with a 13.5 ohm load, I=5A V=67.5V and P=337.5W in the load. Quite a lot, what was the average internal impeadance of a 1930's HT battery I wonder.
26th Feb 2011, 11:14 pm | #27 |
hi, i made one of those a while ago know i use 9v pp3, ive just baught some jerman varta aa batts for 58p for 4 from local super market, oh theirs not much of a kick from 90v i just touched my 110v batt erray actually its about 120, it was just a tickle low current i suppose, fusewire.
26th Feb 2011, 11:41 pm | #28 |
The human body is a bag full of salty water, a few kilo ohms resistance, it's the skin that stops us being killed by a few 10's of volts. There is some data on the likely effect of voltage, current and type of contact (wet/dry hands AC/DC etc.) it came, somewhat worringly, from the US penal service.
26th Feb 2011, 11:42 pm | #29 |
These set-ups must have a reasonable current available, as they will easily light standard GLS lamps, though probably not for long. The shock from a DC battery will feel different to that of an AC supply of the same voltage.
27th Feb 2011, 12:01 am | #30 |
Dont forget that John Logie Baird was nearly killed joining up torch batteries
Kevin |
27th Feb 2011, 12:03 am | #31 | |
27th Feb 2011, 4:38 am | #32 |
Killer---love the name!
Just playing with high voltage.... |
27th Feb 2011, 4:22 pm | #33 |
When I tried to solder some wires to AA cells, one of them exploded. I was Ok, but the crack was deafening and my ears took a minute or two to recover. I haven't tried it since.
Perhaps this is why these cells are supplied with solder tabs where needed rather than try to do it yourself. |
27th Feb 2011, 5:37 pm | #34 |
Were they alkalines or rechargeable NiCd / NiMH types? - those warn against soldering wires.
Never seen a tagged primary cell except for Li types.
1st Mar 2011, 7:11 pm | #35 |
They were Ni-Mh AA size with no solder tag.
The problem occured as I was tinning the base to take a wire. If you search a popular auction site for 'AA tab', you will find some green Ni-Mh cells with tags. (note TAB for the search, not TAG). I suggest you use these rather than try to solder wires to Ni-Mh cells. I've more recently used the blue-covered Li-Ion ones further down the page from the USA (branded TENERGY) and they are excellent. The tags have a fairly weak spot weld, so don't bend them through a too-tight angle. Last edited by dennishoy; 1st Mar 2011 at 7:24 pm. |
1st Mar 2011, 7:15 pm | #36 |
Commercial sell stacks are usually spot or laser welded using thin metal strips to connect the cells together.
Alan |
