Old 8th Feb 2013, 12:54 am   #81
trellis
Default Re: Archive of tapes - Reel to Reel and Cassette.
A view of the top edge of the "Verbatim" data cassette, showing the 'flippable' record protect tabs, and the offset notch (presumably used by a computer drive to determine which way round the cassette has been inserted).
trellis is offline
Old 12th Apr 2013, 1:04 am   #82
Jim Davies
Jim Davies's Avatar
Hello
Here's a Maxell UR90 cassette I found recently that seems to be rusting - look carefully inside the little window and you can see something on the windings of tape.
I've never seen this before but I am guessing
a. it's the result of being stored in very damp conditions?
b. it's not really safe to play in a cassette deck without whatever that "rust" is falling off and mucking up the deck?
Any thoughts/explanations would be most welcome but since this is not a discussion thread you are welcome to post to my Flickr page
http://www.flickr.com/photos/6733059...in/photostream
Jim D
Jim Davies is offline
Old 12th Apr 2013, 1:15 am   #83
ben
ben's Avatar
That's mould, it can spread and contaminate other tapes played subsequently, so you might want to try and clean the tape before playing it on anything. Run it in FF over a tissue moistened with alcohol and clean out the shell.
Regards,
Ben.
ben is offline
Old 12th Apr 2013, 1:38 am   #84
paulsherwin
paulsherwin's Avatar
Ben is right. Similar moulds are a big problem with old video cassettes. There's no agreement as to what actually causes it but one thing is for sure - don't play it on anything unless the contents are extremely important to you.
paulsherwin is offline
Old 16th Mar 2015, 3:05 am   #85
ben
ben's Avatar
For those who like to keep the tapes in order here are some scans of the inlay cards to print out and replace those that have been written on or missing!
In no particular order.... more to come.
Name:	emitape hidynamic hlp18 7 inch inner.jpg
ID:	105679   Click image for larger version
Name:	philips lp13 inner.jpg
ID:	105680   Click image for larger version
Name:	philips lp18 7 inch inner.jpg
ID:	105681   Click image for larger version
Name:	philips sp13 5inch inner.jpg
ID:	105682   Click image for larger version
Name:	scotch 220 7 inch front.jpg
Regards,
Ben.
ben is offline
Old 21st Mar 2015, 7:44 pm   #86
Masala_J
National Tape RT-7 Standard Tape by Matsushita Electric Industrial Co., Ltd
Length 370 m, 1,200 ft.
Front and bottom edge shown. Paper and Dymo labels were applied. Used as a home "mix tape".
ID:	105904   Click image for larger version
Masala_J is offline
Old 21st Mar 2015, 7:59 pm   #87
Masala_J
National Tape "Golden Tape" RT-7G by Matsushita Electric Industrial Co., LTD
Length 555 m, 1,800 ft. Made in Japan.
Was used as a home mix tape, has some paper labels affixed. Front and bottom edge views shown.
Notice how the colours on the front face vary from the RT-7 "Standard Tape" shown in prior posting.
ID:	105911   Click image for larger version
Masala_J is offline
Old 21st Mar 2015, 8:27 pm   #88
Masala_J
National Tape RT-5G "Golden Tape" by Matshushita Electric Industrial Co., Ltd
Length: 277 m, 900 ft
Showing front and back faces (image a), and bottom edge (image b) views. The tape itself in image c.
Was used as home mix tape, adhesive labels, plastic and paper, were applied.
ID:	105921   Click image for larger version
ID:	105922   Click image for larger version
Masala_J is offline
Old 21st Mar 2015, 8:50 pm   #89
Masala_J
National Tape RT-3G "Golden Tape" by Matsushita Electric Industrial Co., Ltd
Length 93 m, 300 ft.
Showing front and rear (image a), corner view (image b) and the tape itself (image c)
Was used as a home mix tape. Some ink writing on the packages.
ID:	105928   Click image for larger version
ID:	105929   Click image for larger version
Masala_J is offline
Old 2nd Mar 2016, 11:50 pm   #90
jascha
Hi, do you have a picture of the spool of the RT-7?Does it differ from the RT-7G that has the golden sticker on the spool? Thanks
jascha is offline
Old 8th Mar 2016, 11:56 pm   #91
Baguette
Trying to avoid duplicates
Maxwell UD 25-120, Japan
Radiola RA3953, France
Kodak but with an ORTF sticker, the french agency in charge of TV and Radio from around 1960 to the late seventies, so probably broadcast quality.
What is this strange tape? It's dark blue. When played I only hear small crackles. Oxidation perhaps?
ID:	121287   Click image for larger version
ID:	121288   Click image for larger version
ID:	121289   Click image for larger version
Baguette is offline
Old 14th Mar 2016, 6:57 pm   #92
jamesperrett
I believe that Racal used to make tapes with a blue backing - the magnetic side was a dark grey-ish brown.
jamesperrett is offline
