Reply
Old 3rd Aug 2005, 8:43 pm   #81
rigsby27
Default Re: AVO Multimeter survey
My new baby,
Fully working with help from SPCh, Avo 8 Mk II serial No. 35373-C-655 after a clean looks the part against the yellow DVM's I normally use.
Tony.
rigsby27 is offline   Reply With Quote
Old 3rd Aug 2005, 8:49 pm   #82
Brased
My three for the file.
Model 7 (no Mk no.) No.22528-A-251
Model 8 Mk 3 No.27246.1065
Test set multirange No.1 No.4433-15-1062
Edward
Brased is offline   Reply With Quote
Old 3rd Aug 2005, 9:23 pm   #83
GW4FRX
GW4FRX's Avatar
My much-loved 8 Mk II was intercepted just before being despatched to a BBC skip in the early 80s. Its serial is 104096-C360.
Come to think of it, this device could do with some TLC and recalibration. I'd be glad of any recommendations.
John
GW4FRX is offline   Reply With Quote
Old 3rd Aug 2005, 10:03 pm   #84
SPCh
SPCh's Avatar
Thanks, guys.
Edward, your Model 7 is a Mk I (version 2) from 1951
For TLC instructions, consult contributions from PMMunro in earlier threads.
But I suggest that if it works, leave it alone. AVOs hold their performance almost indefinitely - often despite abuse. If you open them up, even just to look, you will allow dust ingress, moisture ingress, magnetic contamination/deterioration, and all sorts of handling-induced problems.
If it ain't broke ... resist the temptation to do what we all instinctively want to do.
SPCh is offline   Reply With Quote
Old 5th Aug 2005, 3:20 pm   #85
calum
Originally Posted by SPCh
I am trying to compile an unofficial history of the AVO multimeter (unofficial beacause there is no official interest in the project).
I don't suppose you're interested in my Avo 8 Mk.7 details, bit too new? Still, it must be almost 15 years old, so not *that* new
Is your history ready for reading anywhere? Looking forward to seeing it...
calum is offline   Reply With Quote
Old 5th Aug 2005, 5:38 pm   #86
SPCh
SPCh's Avatar
All information is valuable & gratefully received.
Most of the contributions have been for Model 8, very few have been for the real oldies (pre Model 7).
Despite everyone's sterling efforts, there are still not enough (of each type) to make a "story", yet, except that hand calibration of the many thousands churned out during WW II must have run up an enormous number of man- (or probably woman-) hours. Can't imagine who was left to actually do any fighting !
Keep them coming.
Old 5th Aug 2005, 6:00 pm   #87
calum
ok, then.
My Avo 8 Mk.7 has serial no: M7555901007 1092
I know that it was bought between in the early to mid-90s, so I can easily believe that 10/92 indicates the manufacturing date.
It also has the VC-1 10:1 voltage converter to do away with the need for the pesky 15V battery, but I think this might have been ordered as an optional accessory.
Works perfectly, of course, and so much more fun than my soulless digi meters.
Old 5th Aug 2005, 7:34 pm   #88
Brased
Three more from a museum where I'm a volunteer.
Model 7 No.7246-25586.
Model 7 Mk II No.49823-A-1054. This one is still regularly used some 50 years after construction for repair of vintage wireless equipment.
GPO Meter Multirange No.14C (AKA Avo Model 8 Mk III) No.104536-969.
Edward
Last edited by Paul Stenning; 13th Aug 2005 at 7:12 pm. Reason: OT question deleted
Old 6th Aug 2005, 3:34 pm   #89
Neil Purling
I just collected the Model 8 I got on ebay.
It is a Mk 2, not 3 as the listing said. Sn:119696-C-361.
Last edited by Paul Stenning; 13th Aug 2005 at 7:13 pm. Reason: OT question deleted
Neil Purling is offline   Reply With Quote
Old 13th Aug 2005, 7:15 pm   #90
Paul Stenning
Administrator
Paul Stenning's Avatar
OT questions and responses moved to this thread. Please stick to survey responses here.
Paul Stenning
Forum Admin/Owner and BVWS Committee Member
Paul Stenning is online now   Reply With Quote
Old 18th Aug 2005, 3:47 pm   #91
Lowemission
Lowemission's Avatar
First of all four MOD AVO MK?, please see photo below, sorry about the poor quality.
I have been told that these are panclimatic models ?
7163.370
6259-15-667
13,104-3-72
3633,1267
Yes a few of the numbers them do seem odd
171716-C-266 conventional model 8, MOD
31883-C-255 model 8, civilian
68666-C-567 model 8, civilian
Finally I have two MOD model 40s which don't seem to have serial numbers, I've looked in all the usual places, battery compartment etc, .
Julian
Lowemission is offline   Reply With Quote
Old 18th Aug 2005, 6:15 pm   #92
SPCh
SPCh's Avatar
Okay; a lot of food for thought there.
First of all the picture: it's a NATO Test Set No 1. Essentially a Model 8 Mark II, bit with a 1-3-10 range sequence, no decibels scale, and a metal jacket outside the normal plastic one, with earthing screw at the top. (A nice bit of kit, but changing to a 1-3-10 range sequence AND deleting the dB seems a bit bizarre).
The first four on the list sound like Panclimatic variants of the Model 8 Marks IV, III, IV and II respectively.
The last three "honest" Model 8s are almost certainly Marks III, I and III respectively.
Old 19th Feb 2006, 11:34 am   #93
maitiustandun
hi head, my multimeter is an 8x , no. 170566.c.265, bought recently from ebay ,tag attached devonport royal dockyard ,weapon factory , f.a.o ray bulley , cost 7.50 gbp , posted to dublin at a cost of 30 euros , regards maitiu
maitiustandun is offline   Reply With Quote
Old 26th Feb 2006, 4:48 pm   #94
reneblc
Several models from my schack (in Belgium) :
Model 40 - Part N 10945-32A - N 20887-B-1161
Model 7 MKII - Part N 3284-144 - N 101491-A-1266
Model 8 - Part N 13574-3 - N 36416-C-755
Avominor - N U.15/134-843
EA113 Electronic Avometer - 2554-171 (on dial) - 2284 (on the rear)
Best whishes for your harvest ! Ren
reneblc is offline   Reply With Quote
Old 27th Feb 2006, 4:03 pm   #95
harrybeadlebaum
harrybeadlebaum's Avatar
Avometer Model 8, Serial No: 10725-C-253
Bought by my Dad, in London, sometime in the late 50's. Rarely used.
harrybeadlebaum is offline   Reply With Quote
Old 16th Mar 2006, 4:05 pm   #96
Tim B
Two more:
Avo 8 mk3, serial no. 89965. 1268. This was originally sold in Germany, and has the instructions plate in German. The controls and scale are in English however.
Avo 40 mk2, serial no. 20315-B-1260.
Tim B is offline   Reply With Quote
Old 16th Mar 2006, 6:28 pm   #97
Chris_C
Chris_C's Avatar
Model 7 Mark 2 serial# 83193-A-160
Chris C G8TJR
Chris_C is offline   Reply With Quote
Old 16th Mar 2006, 8:24 pm   #98
Jim - G4MEZ
Jim - G4MEZ's Avatar
AVO 8 MKIII Serial 11058.265
Jim - G4MEZ is offline   Reply With Quote
Old 19th Mar 2006, 11:58 am   #99
Zulu95
Avo Universal Avo Minor U 48422-742. Belonged to my grandfather, he kept it in an OXO box where it is still housed today. I figure it might be from the 1930s or 1940s.
Zulu95 is offline   Reply With Quote
Old 19th Mar 2006, 12:52 pm   #100
percival007
percival007's Avatar
Hi SPch,
i've allready pm'd you with my serial numbers i think, if not, please let me know and i'll do so but allmost certain i have. Still adding more to my collection though, so will probably give you an updated list at some point!
How far are you away from finishing the survey (how long is a piece of string, i guess?!)? Any plans to publish? I would love to read a book on the development of the Avo meter and the company in general.
All the best and keep up the good work, Percy.
percival007 is offline   Reply With Quote
Reply
