24th Sep 2008, 8:19 am | #1 |
AVO CT160 valve tester top cap lead
I've had this CT160 for a few years and have only just realized that its missing its top cap lead, can anyone please tell me what the lead end which plugs into the valve tester sockets is like ? The socket holes are quite a bit smaller than the standard banana / wander plugs I have, I don't expect anyone would have a spare, but I could probably make one in my workshop if its just a plain diameter end, not sprung. Any information would be helpful.
Thanks John |
24th Sep 2008, 8:27 am | #2 |
Re: AVO CT160 valve tester top cap lead
I simply use a piece of wire of suitable thickness, with the strands folded back along the insulation "shoved" in the hole! The other end terminates in an insulated croc clip.
24th Sep 2008, 9:09 am | #3 |
That's more or less what I did this week, doubled a piece of single strand wire over, but I'd like to make a more authentic looking one.
John |
24th Sep 2008, 10:34 am | #4 |
The one which came with my CT160 has a black split pin type plug at one end and a croc clip at the other. Croc clip is stamped "38A". Wire sheath colour red. Length about 15".
24th Sep 2008, 11:38 am | #5 | |
Thanks John |
24th Sep 2008, 11:57 am | #6 |
The plug on mine (believed original as it came with my CT160 some 20-odd years ago) isn't split. I've measured the pin at 2.38mm with vernier calipers; I'd suspect it's actually 3/32" (2.38125mm.) Cheers, Kat |
24th Sep 2008, 12:15 pm | #7 |
See attached photo. The plug on this lead is made by 'Clix' (marked in raised letters on the insulator.) I'd be very surprised if this isn't the original lead. I bought the tester from a military surplus dealer at a radio rally in the early eighties, it came complete with mains lead and top-cap lead. Cheers, Kat |
24th Sep 2008, 2:57 pm | #8 |
Just looked at my CT160; lead is exactly like Kat's, as well, and no reason not to suspect it's not original.
Mike. |
24th Sep 2008, 4:28 pm | #9 |
Thanks Kat, thats pretty close, you got 2.38 for the plug and I got 2.35 for the socket, and if the Avo original isn't split it makes it a lot easier to make one, I'll have a go, but will still keep my eyes open for an original, now I've seen a photo I know what I'm looking for. and thanks Mike for the confirmation.
John |
24th Sep 2008, 4:35 pm | #10 |
So mine's obviously not original. I shall be having a few sleepless nights worrying about that
24th Sep 2008, 4:46 pm | #11 |
I'll look out for two Graham, but don't throw the other one away yet.
Probably close this thread now Mods. Thanks again John |
24th Sep 2008, 4:48 pm | #12 |
It's OK John. I'm perfectly happy with the lead I have. It does the job and that's all that matters to me.
