Old 27th Jun 2008, 9:02 am   #1
Variometer
Default ACORN 1 - the final version
I have now laboriously made a new set of components for the final build. The veneered baseboard will be cut down to the correct size & the rough edges hidden behind front & back panels & alumnium sides. The brass strips will be polished, but the straight wiring can remain as it is (enamelled heavy guage copper wire).
Bob
Name:	Acorn 1 parts (Medium).JPG
Variometer is offline
Old 28th Jun 2008, 4:26 pm   #2
Variometer
Default Re: ACORN 1 - the final version
The aluminium side angle have now been fitted to the baseboard. The coil & valvholder are in position & all the brass strip wiring. The brass strip is no longer all "earth" connections. The right-angle on the top right hand corner will convey the HT to the primary of the output transformer, whilst the angled piece beneath the valveholder will connect the anode to the other output transformer primary terminal.
Bob
Name:	Brass strips fitted (Medium).JPG
Old 29th Jun 2008, 12:07 pm   #3
Buzzkf9cm
Buzzkf9cm's Avatar
Hi Bob,
Brilliant concept and design. I think your layout is very original.
Great work Bob.
73 de Gary,KF9CM
Valves....The other Integrated Circuit
Buzzkf9cm is offline
Old 29th Jun 2008, 1:59 pm   #4
Variometer
Hi Gary,
Thanks. I completed it half an hour ago. Plugged in LT & valve didn't light, despiate heater being OK. Went down to shed in pouring rain for another. This time it did light & on applying HT of 90V all was well & it worked as good as the prototype. Closer inspection of original valve found that it was cracked round a pin, so air had got in!
Sometimes I feel this type of radio is a combination of woodwork, light engineering & radio as well! Lots of nuts & bolts. Made the brass knurled nuts myself. Polished up the brass wiring strips, veneered the baseboard. Front & back panels are glossy black acrylic. Sides are aluminium.
Bob
Name:	Acorn Complete (Medium).JPG
Old 29th Jun 2008, 2:41 pm   #5
Sideband
Sideband's Avatar
Excellent work Bob . It's really like a trip back to the good old days of the hobby. Well done.
Rich.
Sideband is offline
Old 29th Jun 2008, 7:54 pm   #6
chipp1968
chipp1968's Avatar
Very smart , good work
chipp1968 is offline
Old 29th Jun 2008, 9:34 pm   #7
dave walsh
Really excellent and interesting further version Bob! Worth a trip to the shed in the rain! It's been baking hot in Sussex so will stay put for a while. Dave W
dave walsh is offline
Old 29th Jun 2008, 11:30 pm   #8
murphyv310
murphyv310's Avatar
Hello.
Cracking job! Really nice and the way it should be done, award yourself 10 points.
Trevor
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is online now
Old 12th Sep 2008, 10:30 pm   #9
boiss
boiss's Avatar
Hi Bob
Super job! The brass strips are an excellent idea fixed to the base plate.
It's given me a few ideas for my next toy!!
Mike.
boiss is offline
Old 12th Sep 2008, 10:46 pm   #10
petervk2mlg
petervk2mlg's Avatar
Brass strips are a great idea - rather like the way the old Telefunken Arcolotte was built in 1929/30- a very early kind of pcb!
Peter
petervk2mlg is offline
Old 13th Sep 2008, 7:47 am   #11
Variometer
Thanks, I got a big box of brass strips from a car boot sale for next to nothing some time ago. They are stuck down with double-sided tape, but the joints are soldered & nuts & bolts put through in the middle of the longer lengths. It wont matter about eventualy failure of double-sided tape because the completed wiring holds everything firm.
Bob
Old 23rd Sep 2008, 11:55 am   #12
humphrey
May I have a link to the original thread?
humphrey is offline
Old 23rd Sep 2008, 1:36 pm   #13
Variometer
Hi Humphrey,
The first part of this build can be found here:-
https://www.vintage-radio.net/forum/...ad.php?t=29295
entitled "The Paint Tin Acorn one prototype".
Details of the paint tin tuning coil are in thread
Tuning coil made from paint tin
Bob
Old 11th Aug 2014, 1:01 pm   #14
Dave757
Default Re: Socket for an acorn valve
Hi
I wonder if anyone has the circuit for the Acorn Valve receiver?
Most of it is clear from the pics, but it would be nice to have the
coil details etc.
Kind regards
Dave
Dave757 is offline
Old 11th Aug 2014, 4:57 pm   #15
David G4EBT
David G4EBT's Avatar
Originally Posted by Dave757 View Post
Hi
Most of it is clear from the pics, but it would be nice to have the coil details etc.
Dave
Bob - 'Variometer' will have - he designed it, and I'm sure he'll be only too pleased to note your interest and would probably be happy to send you the circuit if you drop him a PM. (He regularly checks into the forum, most recently on 10 July). He recently wrote an e-book on how to make your own one valve receiver using either an HL2 triode or an EF91 pentode entitled: 'Vintage Radio & Electronics For The Home Constructor - A One Valve Battery Receiver'.
The e-book shows how to build a one-valve radio receiver using only a few components. It is perfectly safe for all ages, as the power supply is from six 9 Volt batteries connected in series to make up the required 54 Volts for the H.T supply. Two versions of the circuit are described - the first uses a very old HL2 4-pin triode valve - the second version make use of the far more common EF91 pentode valve in place of the HL2.
However, in March this year on the forum, Bob reported that (to use his words):
"This e-book was a complete and utter failure and has now been abandoned (by me). However, I will be happy to e-mail it to anyone free of charge if they send me their e-mail address in a PM".
See post #22 at this thread:
https://www.vintage-radio.net/forum/...784#post669784
Hope that helps a bit.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 12th Aug 2014, 1:30 am   #16
Dave757
Many thanks David
Kind regards
Dave G0ELJ
Dave757 is offline
Old 12th Aug 2014, 1:00 pm   #17
Variometer
Here is the circuit with component values. L1, L2 and L3 are small RF chokes 47uH each, inside the coil can. The coil connection labelled "can" is just soldered to the can on the inside. The connection just goes to earth. If the reaction does not work, just reverse the connections to coil 4 and 5!
Bob
Name:	Acorn 1 Circuit With Component Values.jpg
Old 12th Aug 2014, 5:43 pm   #18
David G4EBT
Nice to see this thread re-awakened! I recall being very impressed with the original back in 2008 and thought that using a Humbrol tinlet for the coil screening can was a nifty idea, as was the use of three 47uH chokes for the tuning coil to save coil winding - often the biggest hurdle for homebrew sets.
I'm awaiting delivery of some 958-A acorn triodes (1.25V heater version of the Acorn series, rather than the more usual 6.3V). It might just fire my interest, but that said, I still have all the bits in a box, including coils that I wound, for a Short Wave Mag Acorn 3-valver, still waiting to be assembled since goodness knows when! Trouble is I've been retired for 20 years and it's a full time job with long hours, so I get little spare time for projects, and the 'do list' gets longer with each passing week.
David.
BVWS Member.
Old 12th Aug 2014, 7:29 pm   #19
Variometer
I wrote the Acorn 3 article in the Short Wave mag years ago, although the AF amp was not an acorn. It worked well, but if I remember correctly, they forgot to put the values on the capacitors on my RF tuning switch and also missed a dot (wires joined) from the circuit that would have prevented it working.
Nice to see interest reviving in this sort of thing. I have not done any radio for some months now as interest in "homebrew" seemed to be at an all time low.
Bob
Old 12th Aug 2014, 8:40 pm   #20
David G4EBT
I've just dug the SWM article out Bob, and the one that I'm referring to was in fact by an author called Brian Adkinson and used three 945 Acorns. The article was spread over four issues of SWM from October 1992 to Jan 1993. I got all the bits together in 2003 and they're in hibernation waiting for me to awaken them from their slumbers! A fellow forum member who is a prolific home-brewer ('Peter') built one in very short order back then when I passed him the article.
One day perhaps...?
Sad to say that you're right about home-brewing - it mirrors other hobbies - model engineering, woodturning, aero-modelling, model boats - you name it. Many people have a passing interest in such activities, but are passive rather than active participants. They may buy a magazine or two from time to time, but that's as far as it goes.
David.
BVWS Member.
