| Vintage Radio (domestic) Domestic vintage radio (wireless) receivers only. |
#1 |
Hi. Any problems using 200mA 3.5 volt bulb instead of 150mA as per Trader sheet on a Ultra Troubadour?
Many thanks. |
#2 |
If it is part of the heater chain, then it will probably light up slightly dimmer. I don't know this particular set or circuit, but I doubt it would cause any damage.
If you live, the chassis was dead; if you're dead, the chassis was live !!!! |
#3 | |
Alternatively use a 6.3V or 6V 150mA lamp which are easily obtained. Again you'll need to alter the value of R15. Experiment to see what works best. |
