Old 12th Nov 2022, 6:17 pm   #1
Dorian27
Default Hunts capacitors
I have a very small Hunts capacitor that. has been dammaged it a 0.001uf 400v. Can i replace with a 630 volt one instead of 400v
Dorian27 is offline
Old 12th Nov 2022, 6:24 pm   #2
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Hunts capacitors
Yes. If it is a decoupler make sure it is fitted in the same physical place as the original. It will probably be smaller but no problem. J.
Heatercathodeshort is offline
Old 14th Nov 2022, 7:09 pm   #3
whiskas
whiskas's Avatar
Any capacitor rated at 400V or higher that will fit will be OK.
Of course, it's best to use on of the same type (e.g. film)
It would be worth checking for any other Hunts capacitors that are present as they are usually best replaced on sight.
...where on earth did that spring/screw go??
whiskas is online now
Old 14th Nov 2022, 9:32 pm   #4
pmmunro
Is that true for all Hunts capacitors, including electrolytic types?
PMM
pmmunro is offline
Old 14th Nov 2022, 10:16 pm   #5
Techman
Techman's Avatar
I think we all know that Hunts made some of the best electrolytic capacitors that there are - probably more by luck than design, though.
We need to try to remember to be specific when advising on things like this to save on possible confusion.
Techman is offline
Old 16th Nov 2022, 2:53 pm   #6
Station X
Station X's Avatar
One post moved to a new thread here:-
https://www.vintage-radio.net/forum/...d.php?t=196057
Graham. Forum Moderator
Station X is online now
Old 16th Nov 2022, 3:08 pm   #7
paulsherwin
paulsherwin's Avatar
Hunts were not a particularly poor manufacturer. It's just that the technology used to make consumer grade capacitors in the 1940s and 50s has a finite life - these things are over 60 years old now. British restorers also encounter a disproportionate number of bad Hunts caps simply because Hunts supplied most of the UK manufacturers.
paulsherwin is online now
Old 16th Nov 2022, 3:33 pm   #8
McMurdo
McMurdo's Avatar
Indeed, youtube's american restorer Shango066 has choice words to say about american-made vintage capacitors from Mallory, Sprague, Cornell Dubilier, Aerovox and a thousand others. I doubt he's changed many Hunts over there!
Kevin
McMurdo is online now
Old 18th Nov 2022, 4:45 pm   #9
G6fylneil
My Eddystone only had one "Mouldseal", which I replaced years ago, but the "Dipseal" ones are all still functioning.
G6fylneil is offline
Old 18th Nov 2022, 7:18 pm   #10
stevehertz
stevehertz's Avatar
Paul, that's one way of looking at it. I'd tend to think that to some extent they just 'winged it' when using dielectric and outer casing materials that they had little or no knowledge of WRT how long they would last even in relatively stable, un-arduous conditions. The bottom line is, there are good and bad caps from the same era, and Hunts produced some shockers.
stevehertz is offline
