16th Sep 2022, 11:20 am | #1 |
Vintage Clock Bobbin rewind
Where can I get my bobbins rewound for my old clock. Mains powered synchronous 240vac. What approx cost ?
Can anyone Identify the clock please. It is devoid of all markings and numbers, has a cat aluminum enclosure and a 7" face all encased in solid brass . Thanks for looking. |
16th Sep 2022, 12:24 pm | #2 |
Re: Vintage Clock Bobbin rewind
Hello and welcome.
What an unusual clock. I would have guessed that it was a slave clock at first glance. I don't recognise the movement. It certainly looks very early. Any chance of some better pics (perhaps taken outside and uploaded in higher resolution)? Send a Private Message to forum members Ed Dinning and Murphymad, as they're the experts in coil re-winding. https://www.vintage-radio.net/forum/...do=newpm&u=215 https://www.vintage-radio.net/forum/...do=newpm&u=511 Nick. |
16th Sep 2022, 12:37 pm | #3 |
Thank you, Nick, I'll try getting some higher res pics and upload them.
George |
16th Sep 2022, 5:20 pm | #4 |
Hello George,
Have a read of this excellent article https://sound-au.com/clocks/ocm.html. Basically, what he suggests is rewinding the bobbin for a lower voltage using much thicker wire. I used this method to repair a 1930s Hammond electric clock movement and it's still going 8 years later. I made a new bobbin from cardboard, used epoxy resin to strengthen it and then filled it with 0.315mm (30SWG) enamelled copper wire which is substantial enough to wind by hand. As predicted in the article the motor ran at about 15V AC and is now fed from an old "wall wart" transformer making it considerably safer than the original design. Have a go there's nothing to lose. Len
Member of BVWS and VMARS. MCR21 Volunteer. |
20th Sep 2022, 8:36 pm | #5 |
That is almost certainly a slave clock, please don’t connect it to the mains. That is maybe why it needs a rewind as somebody may have put the mains on it in the past by mistake. It’s an unusual movement that I’ve not seen before.
You will need a master clock to drive it or a slave impulse device. It would be good if you could fit the minute hand and toggle the mechanism and see what time interval it advances by it will be either 1/2 min or 1 min, it looks like 1 min from the photo, with a rocking ‘lever’ advancing 1 min in each direction of the ‘lever’. Enjoy |
21st Nov 2022, 5:18 pm | #6 | |
Learn what you don’t know, share what you do! |
21st Nov 2022, 5:22 pm | #7 | |
21st Nov 2022, 6:15 pm | #8 | |
21st Nov 2022, 10:31 pm | #9 |
Good stuff, glad you got it running, it looked like 1 minute impulses were required, but not easy to determine via photos without being able to ‘play’.
