13th May 2022, 6:36 am | #1 |
Germanium transistor replacement
I saw this interesting message but I like to know how the story continues. https://www.vintage-radio.com/repair...or-faults.html Is there any list available how I can interchange old Germanium-type transistors? What about the other BIAS when using Silicon transistors? A general chart list will be fine..... Happy weekend, German Dalek
And now something completly different: MARC BOLAN, he was/is the real king of Pop Music! |
13th May 2022, 8:53 am | #2 |
Re: Germanium transistor replacement
Hi to all,
Hi German Dalek, An interesting series of chapters (look at upper right of home page) on replacing Germanium transistors with Silicon and the bias changes required for proper operation : http://www.hawestv.com/transistorize...htm#conv_intro Hope this helps with what you want to achieve, Best Regards jhalphen Paris/France |
13th May 2022, 10:30 am | #3 |
In the majority of cases there is sufficient tolerance within the circuit and transistors themselves to operate without bias changes. Early Ge transistors had a wide spread of characteristics, and the circuits designed for them had to work with all of them.
The big exception is the audio output stage, which almost always requires circuit changes to work properly with silicon. |
13th May 2022, 11:33 am | #4 |
As an example, a couple of weeks ago I had to replace a dead AF117 frequency changer in my Bush TR130 transistor portable. The only PNP transistor I had to hand was a common-or-garden silicon BC214. It works fine. It of course ran at a lower collector current because of the higher Vbe of the silicon device, so I increased it by lowering the emitter resistor value. But that made no apparent difference to its performance.
Martin
BVWS Member |
13th May 2022, 11:41 am | #5 |
I've also found the BC214 to be a reasonably reliable AF11x substitute, but I only use them because I bought a big bag of them for peanuts years ago so have hundreds of the things. Modern BC55xs or 2N3906s will probably work just as well. It's always worth trying whatever you have to hand.
13th May 2022, 12:17 pm | #6 | |
13th May 2022, 12:31 pm | #7 |
There are quite wide spreads in transistor parameters, so in a lot of respects you can get away with murder. But the most dependable parameter is Vbe. Roughly assumed to be 0.7v for Silicon, and close to half that for Germanium.
Carefully designed circuitry takes into account fairly large variations in gain from device to device, but Vbe is taken as almost gospel. Where things get difficult is in circuitry with either very low supply voltages, or with very crude bias arrangements. You need to look at the circuitry around each transistor being replaced to spot these cases and then consider bias resistor value changes. Most often, you can do the job by changing one or two resistor values, but you do need to check. Silicon still has a significant sensitivity to temperature, but it's much tamer than Germanium, so substitution is often an improvement. In general temperature compensation with germanium transistors was a problem, and often not done, so you aren't likely to run into trouble with too little temperature sensitivity. The current gains of some Germanium power transistors were somewhat better than many silicon types, so care is needed here. David
13th May 2022, 6:01 pm | #8 |
I recently replaced a noisy OC71 (PNP) with a high gain BC558 (PNP) and changed one of the bias resistors. This is in a Decca TP85 (1963).
It works but needs adjusting. This first audio stage seems to have been originally designed for minimum current consumption. The emitter current is about 30 microAmps. The collector voltage is near Vcc and so there is not much room for voltage swing. Leakage through the bypass capacitor which is across the emitter resistor, and leakage through stage coupling capacitors (electrolytic) can have a significant effect on the bias. |
19th May 2022, 2:48 pm | #9 |
Many thanks to all for your inputs!
I shall work it out, will make a nice translation of it and bring it to book standard. The print-out will be saved. Then I shall see, if I have more questions. Best regards, German Dalek
