Old 18th Jul 2007, 12:00 pm   #1
Tim
Tim's Avatar
Default ADVANCE DMM2 bench voltmeter circuit wanted please
Hi all.
Anyone got any service info on one of these please, as I have one with a duff nixie tube.
Also, are they any good?
Thanks
Tim
Tim is offline
Old 4th Oct 2007, 6:40 pm   #2
Chris55000
Default Re: ADVANCE DMM2 bench voltmeter circuit wanted please
Hi!
If they're wire-ended nixies I may be able to assist - I bought four small new ones for a clock project that I never started!
***Alternatively*** - if you're willing to send the meter to me I am willing to:-
1) Repair it with new nixies;
2) Provide a complete parts list;
3) Draw you a full set of circuit diagrams.
I believe these meters were based on an early version of the "dual slope
integration" principle, and were built on three PCBs.
If I can be of help please let me know! If you'd rather not send the meter I'll
need you to measure its original nixies so I can check if the ones I've got will fit!
By the way - is your duff nixie simply broken or physically missing, or does it appear intact and simply not glowing? If it appears intact you may simply have an o/c anode resistor!
Many thanks,
Chris Williams
Chris55000 is offline
Old 8th Oct 2007, 12:43 am   #3
Tim
Tim's Avatar
Thanks for the advice Chris.
The meter has all Nixie's present, just the left most one is completely dead (not even the decimal point works). Happily I have a wire ended spare.
Thanks for the advice re anode resistor/s. I'll give that a whirl, although I haven't actually opened the meter up yet.
Tim is offline
Old 31st Oct 2007, 1:32 pm   #4
Chris55000
Hi!
Watch this space, a circuit might mysteriously appear...!!!
Chris Williams
Old 31st Oct 2007, 1:57 pm   #5
Tim
Tim's Avatar
I log in most days.
Thanks Chris(in anticipation)
Tim is offline
Old 5th Nov 2007, 3:49 am   #6
Chris55000
Hi!
...Part 1!!!
Chris Williams
Old 5th Nov 2007, 3:54 am   #7
Chris55000
Hi!
...Part 2!!!
Chris Williams
Old 5th Nov 2007, 4:04 am   #8
Chris55000
Hi!
...Part 3!!!
Please Note! The Epson Scan Utility I used to get these pages added the "002" suffix to the DMM2 filename and Adobe Acrobat's peculiar numbering of extracted pages from a large file is why there seem to be gaps - in fact there aren't! Please let me know if anything's still missing!
Note also that I wasn't able to get hold of the "BP2" Battery Pack and "SP2" Shunts Accessories Page! Any 12-14V rechargeable battery can be used with this whilst you can probably make or buy shunts from the info supplied!
Chris Williams
Old 5th Nov 2007, 3:06 pm   #9
Tim
Tim's Avatar
Thanks Chris
Tim is offline
