#1 |
I have been given a HMV record player from the 50's thats been stored in a cupboard for at least 30 years.
The power /volume control is missing, there is no model number anywhere. Does anyone reconise it? I would love a circuit diagram so i can restore it properly. I have stripped the deck and set it up and it works a treat, the cartridge was dead so found a replacement. Now my attention to the amp which has some dodgy caps in it plus a burnt out resistor, hence tge need for a circuit diagram. Can anyone help please. |
#2 |
Hi
Possibly a 2009 https://www.radiomuseum.org/r/hismasters_2009.html Service info here: https://www.service-data.com/product...3/12587/m18963 Cheers Mike T
Don't care if it was a bargain why's it in my kitchen ![]() Mike T BVWS member. www.cossor.co.uk |
#3 |
Very many thanks for that much appreciated.
Now perhaps i can fix it. |
#4 |
The cartridge as shown in your photos is a Mono turnover type - so be careful what type of LP records you play on it!
Edward. |
#5 |
I have since then replaced the cartridge with a stereo one, wired mono, but i think i will just use it for 45's if i can get the amp working. Got a circuit thanks to cobaltblue but still no sound. Don't get much free time at the moment so will need to go through the amp in stages changing the caps.
#6 |
Your fault as described is somewhat confusing. What does "power/volume control missing" mean? - I can see that it's still there.
Edward. |
#7 |
The volume control in the picture is my replacement, but can anyone tell me what value the caps should be ? Most are broken so new ones will need to be fitted, but i can't work out if they should be pf or uf from the diagram.
#8 |
If you have excessive hum, that long trailing lead to the rear "stereo" socket (which you will not be needing) could be a possible culprit.
Edward. |
#9 |
Some of the capacitors, especially around the tone and volume controls, are shown as μμ(F) (note the double μ symbols) which is the same as picofarads. Other values such as that for C6 and C8 are in μF.
#10 |
Those caps around d the input and tone control circuit are unlikely to need replacement.
#11 |
Unfortunately when someone removed the original volume control they damaged the caps and renderer them useless, hence the need to replace them.
Thank you for your help. |
#12 |
uuF is the American pF so something marked as 470uuF is the same as 470pF. I think there were a few British companies that used uuF for a short time.
On Spike Milligan's headstone......I told you I was ill... |
#13 |
I now have it up and running good amount of volume and the tone control has quite a good range, however, the bass control does nothing ?
I am not expecting a lot of difference, but something should happen ! The control itsself is ok and so are the resistors its c3 i am questioning, what value do you think it should be it just says .003 ? Any ideas please ? |
#14 |
In that position, it's got to be .003uF! Same as 3000pF. Nearest modern replacement is .0033uF or 3300pF.
#15 |
The lack of a suffix shows that C3 is 0.003uF by default.
0.003uuF or 0.003pF is a ridiculously low valve. You'd never be able to buy one!
#16 |
Is there anything you can recommend please. Just had a closer look and the lead is broken right up to the body so i can't get a solder connection on it.
#17 |
https://www.ebay.co.uk/itm/284368955378
https://www.ebay.co.uk/itm/284368966683 Other sources available. Just use Google.
#18 |
Many thanks for that.
I have placed an order. |
#19 |
Thank you everyone, its finished !
A local museum has shown interest in it as a working model so i am letting them have it . |
