18th Jan 2022, 8:59 pm | #1 |
Eddystone friction drives
Hi Folks, has anyone the details of how to set up these slow motion drives. Mine is on a 770R, but I believe they were used on other sets.
The spindle from the tuning knob is designed to pinch a larhe , thin metal disc that turns the reduction gears. The front panel bush had the bearing section displaced and was easily corrected, but the "pinch " faces do not seem to engage with the disc correctly, even with the tension spring fully tightened. It has been cleaned and degreased and if it is pushed further into engagement (only very little movement) it will turn, but stops when pressure is released Thanks, Ed |
18th Jan 2022, 11:45 pm | #2 |
Re: Eddystone friction drives
Is the hole in the panel bush slightly eccentric, so that rotating the bush will adjust the engagement of the edge of the shimstock disc into the grip of the sprung cones on the tuning knob shaft.
19th Jan 2022, 1:00 pm | #3 |
I restored an S750 recently and it does sound like either a worn bush or the bush is still in the wrong position. The shaft should run as close as possible to the disc and have minimal play. If the gearbox is running freely, the spring does not need to be very tight to provide sufficient friction to work properly.
19th Jan 2022, 8:49 pm | #4 |
Hi Gents, not much play in the main bearing now the bush is in the correct position.
It does not appear to be an eccentric bush for adjustment, but there is some clearance on the case holes where the bush clamping screws fir through. It is however pushed fully over and is still slipping badly. Gearbox appears quite free Ed |
19th Jan 2022, 9:49 pm | #5 |
How about a picture or two?
19th Jan 2022, 10:20 pm | #6 |
I'll see what I can do, but it is sandwiched between chassis and front panel when in situ
Ed |
19th Jan 2022, 10:55 pm | #7 |
The Eddystone User Group has some excellent material by Gerry O'Hara including a document about the dial drive. http://eddystoneusergroup.org.uk/Res...%20Gearbox.pdf. There is a good picture of the flywheel drive attachment.
20th Jan 2022, 10:32 am | #8 |
Hi PJL, thanks for that, looks like just what I need
Ed |
