31st May 2021, 9:18 am | #1 |
Mains Connector Identification
Can anybody identify the name/type of the mains connector shown in photos 1 and 2
The sprung metal contact arms connect to the the earth wire in the 3 core mains cable. I remember this type of connector being used in various vintage equipment such as steam irons etc. The cables in photos 1 and 2 are of the mains cable that came with my Grundig TK 35 reel to reel tape recorder and may well be the original cable for that machine. The TK 35 mains connector on the machine has a metal surround (that I am pretty sure connects to the internal ground connection) that the sprung earth contacts on the cable connector make contact with, so connecting the earth connection. In Post 19 of this linked Thread the OP cals the connector a 5815 (which is the number on his connectors). This Post is specific to the Uher 22 Special tape recorder. https://www.google.com/url?client=in...zihfImU1D8_Fgs I have a Uher 22 Special which came with mains cable as per Photo 3, which is the same type of connector but the earth sprung contact pins have been removed by someone. The Uher 22 mains connector on the machine has a metal surround the same as the Grundig. I have not yet checked if the Uher metal surround is connected internally to the power supply ground/internal metalwork. David Last edited by DMcMahon; 31st May 2021 at 9:23 am. |
31st May 2021, 10:07 am | #2 |
Re: Mains Connector Identification
Don't know what they are called but commonly used on 50's equipment, in my case Madas and similar calculators.
31st May 2021, 10:15 am | #3 |
See numbers 29 & 30 on this page; https://www.plugsocketmuseum.nl/ApplConn_classic2.html
It gives the maker as Kautt & Bux. David |
31st May 2021, 10:59 am | #4 |
Thank you David, I have seen that museum page before but never thought this time to check it.
The inlet item 29 (male chassis connector) shown is the same part as on my TK 35. On the Uher 22 the chassis connector is a more modern metal surround connector. David |
31st May 2021, 11:02 am | #5 |
Had to Google Madas calculator, looks very interesting.
David |
31st May 2021, 11:13 am | #6 | |
David |
31st May 2021, 12:32 pm | #7 | ||
The reference to 15 being the same as the linked Kautt & Bux 24 and 25 appears erroneous, 24 and 25 have single sided earth contact, probably should have said 29 & 30. Also the text for picture 15 identifies the connector in question as 5916, whereas the Czech sourced connectors (which look extremely similar if not the same) in the Uher 22 link shows them to be 5915. David |
31st May 2021, 12:41 pm | #8 |
As an aside the Uher 22 and 24 Hi-Fi Specials were marketed in the USA by Martel as the Uher 9000L.
David |
31st May 2021, 10:27 pm | #9 |
1st Jun 2021, 10:24 pm | #10 | ||
Thank you all for the useful feedback. Mods this Thread can now be closed thank you. I will start a new thread in the Vintage Tape section to cover progress with the Uher 24. David |
