Old 15th May 2021, 12:08 pm   #1
collisr
collisr's Avatar
Default Sony C20 Betamax Unlace issue
Hello everyone,
https://youtu.be/Fcw9TxgvKJA
I have a lovely Sony C20 that has an intermittent fault. All functions are fine except on-occasion, unlace is leaving tape loose in the machine. This only seems to happen if PLAY/FWD is in use before the eject button is pressed. It is also much more frequent a problem when the machine is warm/has been playing tapes for 15mins+
Interestingly if I get the idler to be on the supply spool when eject is pressed, the problem doesn't occur.
I have oiled the lacing ring AND the supply/take-up spools plus checked the idler - seems to flip about with ease.
Any ideas? I've seen this on the Sanyos but not on the Sonys.
Thanks in advance
Rob
collisr is offline
Old 15th May 2021, 12:38 pm   #2
TIMTAPE
Default Re: Sony C20 Betamax Unlace issue
There's a known issue with the pendulum idler mechanism in these models which can be hard to repair these days. There are some details on the Betamax Palsite.
https://www.palsite.com/slc20tech.html
TIMTAPE is offline
Old 15th May 2021, 4:25 pm   #3
collisr
collisr's Avatar
Thanks Timtape. I did look there and they talk about checking a resistor and a transistor (2SC10613). They don't say what board this is on and I don't have the service manual for the C20.
I don't think it's the idler (pendulum) bearing but I will check that out too
collisr is offline
Old 16th May 2021, 7:56 pm   #4
dj_fivos_sak
Hi Rob
Q334 (2SC1061) is located in the SS-16 (syscon & servo) board.
Regards,
Fivos
dj_fivos_sak is offline
Old 16th May 2021, 10:14 pm   #5
ben
ben's Avatar
I had this problem with a c30. Intermittent loop of tape on eject. I had to lubricate the idler on it shaft and also apply heat to it/bend it as it was slightly warped and wasn't always making proper contact with the spool table.
Regards,
Ben.
ben is offline
Old 17th May 2021, 8:00 am   #6
collisr
collisr's Avatar
Fivos/Ben,. Thank you. I'll investigate both avenues.
collisr is offline
