26th Mar 2021, 7:08 pm | #41 | |
Re: Mini-Mod 2021!
I'm still leaning towards using holders though, under 8x magnification the soldering iron looks like a crowbar!
Regards, Ken. BVWS member |
27th Mar 2021, 3:14 pm | #42 | |
Re: Mini-Mod 2021!
I had bought some 60p plastic knitting needles from Home Bargains, whittled one down to fit the IF adjusters in a valve radio, but this was too big. A cocktail stick pared-down with a Stanley knife is easiest and quick! Happy Listening! SR |
27th Mar 2021, 4:25 pm | #43 | |
Re: Mini-Mod 2021!
The MiniMod does not cover the complete band, but a few hundred kHz (about one third of the band) in the middle. If anyone really needs to have it elsewhere, then increase or decrease both C1 and C13 by 50pF or so. Ian |
27th Mar 2021, 4:27 pm | #44 |
Re: Mini-Mod 2021!
My boards arrived today, very well made. Here's hoping there hasn't been a run on the components from Cricklewood electronics!
27th Mar 2021, 5:55 pm | #45 |
Re: Mini-Mod 2021!
Don't forget Spectrum Electronics have a kit of coils, fet, transistor and IC on ebay.
I am not associated with them but have communicated with them and they assure me that they have plenty of components available. Peter |
6th Apr 2021, 1:03 pm | #46 |
Re: Mini-Mod 2021!
My Mini-Mod 2021 completes a set of three Pantry Transmitters for use around the house. It also encouraged me to box-up the one I built from David's PCB a few years ago. The third unit is one I've had a few years now, it's the AM-03 that used to be sold by Geoff Hopkins. It worked well, but is no longer made.
Thanks again to Peter for sharing-out these PCBs. Anyone else finished theirs yet? SR |
6th Apr 2021, 1:45 pm | #47 |
Re: Mini-Mod 2021!
Here are two of mine, both working well. I've used some different caps/resistors in each, depending on what I had to hand.
One uses a 470nF cap (red) for the audio coupling and the other uses a 680nF (yellow). I couldn't tell the difference. The LEDs are low current types, taking a fraction of a milliamp. The blue LED draws less than 40uA. |
6th Apr 2021, 10:35 pm | #48 |
Re: Mini-Mod 2021!
Nice ones, Steve. I especially like the retro looking audio cable on the left unit.
I can't remember what my LEDs are rated at. I know they are branded 'Kingbrite' and sold as superbright. I bet they are using most of the available power! Kind Regards, SR |
7th Apr 2021, 2:52 am | #49 |
Re: Mini-Mod 2021!
I've been trying to find the explanation why Ian decided to leave the 2N3819 for the BF256 but haven't found anything. Can anyone (perhaps Ian) advise? I've got genuine 3819's sitting in the junk box as a well as quite a few 2SK19, which were popular in FM tuners and have served me well as a general purpose J-FET.
Thanks B
7th Apr 2021, 10:03 am | #50 | |
Re: Mini-Mod 2021!
The reason I changed the 2N3819 for a BF256 was because after making about 30, I had one or two that gave poor modulation. I tracked this down to insufficient drive to Q2. It seems the performance characteristics of the 2N3819 are quite wide, so some just weren't up to the job. I expect J310s would do but I haven't tried them. I also found that changing Q2's base resistor from 10k to about 3k3 also slightly improved things using the BF256. Like most circuits the design is generally fairly tolerant of component values (+/- 20% shouldn't be a problem) except perhaps C1 and C13. Any transistor equivalents should work, but be very mindful of the lead configurations! I did find that mica or good quality ceramic capacitors used at C1, C2 and C13 gave a bit more output than polystyrene ones. (Cheap disc ceramics used for C1 or C2 might introduce temperature-dependent frequency drift.) See this post: https://www.vintage-radio.net/forum/...&postcount=150 Also remember to earth one side of the unused winding of L1 to aid frequency stability. The boards supplied by Peter take care of that. After the ones I made and sent out, I wonder how many have been built in total? For anyone not familiar with the simple MiniMod initial setting up, I attach again the instructions I sent out with the ones I built. Ian PS: I'm glad LEDs now have low enough current not to have any significant battery drain. I think in 2011 when I published the design such LEDs were a bit pricey so I didn't bother. Last edited by Ian - G4JQT; 7th Apr 2021 at 10:29 am. |
7th Apr 2021, 12:16 pm | #51 |
Re: Mini-Mod 2021!
Quick question. Does the indicator led require any resistor in series or are they simply 'plug and play' using this PCB? Or does it depend on the LED?
7th Apr 2021, 12:20 pm | #52 |
Administrator
Re: Mini-Mod 2021!
A series resistor is needed or you will destroy the LED.
R9 on the PCB is the LED series resistor and would be set to suit the LED being used and desired brightness. Around half the LED rated current is a good starting point; for a 2mA LED I would try a 6K8 resistor (assuming 2V for the LED and 7V across the resistor) to give around 1mA as a starting point. Higher resistor and thus lower LED current is better for battery life, as long as the LED is bright enough to act as a useful indicator. |
7th Apr 2021, 12:57 pm | #53 |
Re: Mini-Mod 2021!
Thanks paul
7th Apr 2021, 5:42 pm | #54 | ||
Re: Mini-Mod 2021!
B
13th Apr 2021, 3:05 pm | #55 |
Re: Minimod pcbs for sale
Hi everyone,
I've just built number 1 of the 2 pcb's i got. Works a treat. However be aware. Check your JFET. The one's i have are by Texas Instruments, NOS. They are part number BF256B made around 1983 i think. But the D and S pins are reversed, see bad photo. So watch out. Derek |
21st Apr 2021, 6:41 pm | #56 |
Re: Mini-Mod 2021!
Hi guys, I’ve mostly built up a board now and am hoping for your advice. I bought a jack just like the attached, but confused on how to wire it to the board, where would each wire run to?
Thank you |
21st Apr 2021, 8:49 pm | #57 |
Re: Mini-Mod 2021!
I forgot the photo!
21st Apr 2021, 9:40 pm | #58 |
Re: Mini-Mod 2021!
The audio input on the pcbs can be either a miniature 3 way socket or by vero pins or wires direct to the Board.
For the socket shown connect the longer terminal to one of the 0V points. For the shorter terminals connect one to the point marked L and one to the point marked R. It does not matter which as the Left and Right signals are added to form mono. Peter |
22nd Apr 2021, 11:45 am | #59 |
Re: Mini-Mod 2021!
Though it doesn't really matter in this instance as the stereo signals are combined into mono on the Mini-Mod, if ever you're not sure which jack socket solder tag is which, the easiest way is to plug in a jack plug (if you have one) and check the continuity of each socket terminal and tip, ring and sleeve terminals of the jack plug. As depicted in the attached pic, the tip is the left+, the ring is the right+, and the sleeve is the shield.
Hope that might help.
22nd Apr 2021, 1:54 pm | #60 |
Re: Mini-Mod 2021!
This is how I connected my Minimod. Note the fishing line acts as a strain relief just fitted through hole twice. The yellow wire is the sleeve.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
