Old 22nd Feb 2021, 2:04 am   #1
non-entity
Thumbs down Finding old ISDN PRI terminals?
So I'm trying to purchase some ISDN PRI phones. Preferably for E1/EuroISDN networks, but I can't seem to find any. I've been googling for days and all I can seem to find are ISDN BRI phones and VOIP systems. The only PRI related products I can find for sale are trunking cards.
Did anyone actually make PRI/E1 terminals. I have a few old H.320 videoconferencing phones, but they utilize strange interfaces and it will require a lot more research / work to get them working. Ideal I'd like some simpler PRI phones for this project to play with? Did such phones ever exist? Where can I purchase them or at least what manufacturers should I look for?
non-entity is offline
Old 22nd Feb 2021, 10:34 am   #2
cmjones01
Default Re: Finding old ISDN PRI terminals?
The only PRI terminal I've ever encountered was a card in a Cisco router, used to support multiple simultaneous dial-up internet connections. It was useful because it supported V.110 rate adaption, which enabled fully-digital connections from GSM mobile phones. I remember very well that from pressing "connect" on the phone to having a fully configured, working mobile internet connection (albeit at 9600 baud) took 6 seconds. Pretty impressive, even today.
Otherwise PRI connections tended to go to the telephone exchange in the building, not to individual phones.
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is offline
Old 22nd Feb 2021, 3:44 pm   #3
non-entity
Thanks, that sounds about right. I ended up doing some more research late last night and it seems like a typical config was to have different PBX's (BRI, IP, analog, etc.) connected to a central PRI switch, along with serial terminals (mostly V,35 or RS449, in fact the H.320 videophones I mention use one of the two)
Old 23rd Feb 2021, 7:47 pm   #4
G6Tanuki
G6Tanuki's Avatar
Yes I've only come across ISDN PRI stuff in 'commercial' gear - PBX and what in the 1990s was expensive Corporate-quality videoconferencing.
It was a bit-of-a-thing a couple of decades back as a way to replace a 'snake' of analog copper lines into a small-business or a radio-station but they generally got decommissioned [along with the 2b+d basic 64K ISDN circuits to 'outlier' studios] once "Metro Ethernet" became cheap.
G6Tanuki is offline
Old 23rd Feb 2021, 8:44 pm   #5
Sparks
I seem to remember ISDN was something that Canford Audio were pushing more than twenty years ago. One of its applications was enabling stay-at-home radio broadcasters the means to connect their home studio to the appropriate 'hub' of whichever radio station they were on that day.
Sparks is offline
Old 23rd Feb 2021, 9:44 pm   #6
G6Tanuki
G6Tanuki's Avatar
Yes what Canford was pushing was "Basic Rate" ISDN: two separate 64Kbit/sec channels (56Kbit/sec in the US) and a background 16Kbit/sec 'data' channel. Perfect for providing "CD Quality" digital audio between a home-studio and the actual transmitter-infrastructure. The likes of ClassicFM could not have launched without it!.
"PRI" - Primary Rate Interface - ISDN was much heavier-duty: you got a 2.048Mbit/sec pipe [1.536Mbit/sec in the US] channel that could be subdivided to provide loads of separate voice-quality audio channels [for speech-phones] or multiple sub-channels could be 'aggregated' to provide something like 320Kbits/second which was just-about-adequate for videoconferencing.
As noted upthread, this was generally done using 'professional'-grade hardware: I remember some of the Cisco Call-Manager gear from the last-century came with options for PRI cards, and Codian also offered a range of hardware-codecs that could rate-translate between popular US and UK videoconferencing bit-rates.
G6Tanuki is offline
Old 25th Apr 2021, 3:44 am   #7
jimjim1
Polycom HDX 7000 has or is available with a PRI port.
jimjim1 is offline
Old 25th Apr 2021, 4:30 am   #8
jimjim1
Network interfaces included on each Tandberg 6000 are: IP (for H.323 connections), T1/PRI/E1, V.35, and 6 BRI S/T connections (for use in H.320 mode).
jimjim1 is offline
Old 26th Apr 2021, 8:32 pm   #9
dagskarlsen
dagskarlsen's Avatar
Cleaning up at job we will probably throw out an ISDN pax and 4 isdn adapters. (But it is in Norway) I s that actually interesting so may I try to get it out for the cost of the postage to you.
Name:	2021-04-20 07.40.04.jpg
dagskarlsen is offline
Old 26th Apr 2021, 8:34 pm   #10
dagskarlsen
One more picture:
Name:	2021-04-14 08.10.48.jpg
