Reply
Old 20th Feb 2021, 8:57 pm   #1
Cobaltblue
Cobaltblue's Avatar
Default Polycon from Fegusson failed
I put in a request for a replacement which was thankfully responded to by Bill (AC/HL).
I have now replaced the offending Polycon cap and have signs of life although a little way to go as there is the usual AF11*,s and to add insult to injury a bunch of Callins caps.
Going to be a day or two before I can get back to it.
I though I would share pictures of the failed capacitor.
Its been a while since I have had to replace a Polycon so I suspect failures of this type are not that common.
Mike T
ID:	227237   Click image for larger version
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline   Reply With Quote
Old 23rd Feb 2021, 6:02 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Polycon from Fegusson failed
I've seen that sort of failure where someone has given a Polyvaricon 'a good squirt of switch-cleaner' then twiddled it.
The surface-tension of any liquid introduced between the plates and the interleaved dielectric-laminations can make them cling-together enough to tear the dielectric-sheets from their mountings.
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
