Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
#1 |
This is my latest standards converter. It is programmable so can generate a range of standards from a 625 line input. It also comes with a programmable modulator.
The converter can generate a standard with any number of lines from 16 to 830 and any number of active lines(lines with picture content) between 8 and 800. It can generate field rates of 25, 30, 50 and 60 Hz. 50 and 60 Hz are interlaced. It has selectable sync height from 20 to 50% in 5% steps. The length of the front porch, horizontal sync pulse, back porch and broad pulse are all programmable. The number of broad pulses can be in the range of 1 to 50. The left and right of the picture can be cropped independently. There is also a method of moving the picture vertically. The modulator uses two MC44BS373. It covers 30 to 900 MHz in 5 ranges. The frequency step size is dependant on range. It can do negative video and FM sound or positive video and AM sound. It can do video/ audio carrier separations of 4.5, 5.5, 6.0 and 6.5 MHz or if in positive video and AM sound mode the video and sound carriers can be set independently. Both the converter and modulator can be easily programmed by using the two control knobs. Some basic knowledge of the standard you want to generate is needed. I have tested it myself and can confirm it is not idiot proof. It is possible to enter nonsensical settings in such a case it will just sit there not producing any output. I have tested it on 405, 819, 625 and 525 lines. That's as far as my collection of TV's goes. Anything outside those have not been tested but should work. All information needed to build one is on the Hedghog PSC webpage or if you would like one built forum member Freya will supply them. A link to a description of the menu is here Frank
#2 |
Just to add a few photos of it at work.
The first 3 photos below are of 405 lines. They are of the same test card but by changing the active lines, crop and vertical shift it can be displayed in different ways. The next photo is the Sony TV displaying a 819 line picture. The photo of the monitor displaying test card F is a 647 line picture. This is just to make the point it can generate any number of lines not just set standards. I expect running the monitor at 647 lines wasn't great or it but I didn't leave it running long. Frank
#3 |
that looks very impressive, thank you for all the work and time you have put in.
Regards Peter B |
#4 |
Thanks Peter
Frank
#5 |
I see you use PCBway, they do manufacture too, I wonder what they would charge for a few, say 10 or so.
#6 |
That's something I looked into for the first Hedghog. It was very expensive at that time.
Frank
#7 |
Thank you for the insight, I was tempted for one of our little small run boards, I will keep them in house now. And thanks for making it "open source" too.
#8 |
That is awesome thanks for your hard work
Regards Chris
Every Silver Lining Has Its Cloud https://youtube.com/channel/UCvBpiuUUnErJlNBm6DWb3Ww |
#9 |
Thanks Merlin and Chris.
It did take a while to do but was enjoyable, well in-between the times that I was pulling my hair out anyways ![]() Frank
#10 |
Well done Frank.
Will get one when I can rustle up the money. It's an impressive design and very very useful.
#11 |
Excellent !
Had a quick look at the manual, there is a pixels offset left and right, does that mean I can crop? Freeview channels often send a widescreen stream and put black bars left/right so if you display on a 4:3 set the picture looks shrunk horizontally, hoping you can crop off those black bars. Like the idea of presets too. TTFN, Jon |
#12 |
Good day to all,
@ Frank C. : Wow ! amazing achievement. Would the software accept a 720p/50 VGA signal providing a hardware interface could be built to input a VGA signal to your composite input ? Only the Y channel would be needed. Over here in France, there is a growing interest to see what "true 819 line resolution" looked like. Because of HDMI/HDCP licensing issues, this input format is impossible, but VGA is. Your product, as is : Is there a pricing for a built unit ? Does forum member Freya have a web site ? Best Regards jhalphen Paris/France |
#13 |
Thanks Trevor
Thanks Jon You are correct you can crop the bars out. You can even do some extreme cropping ![]() The second photo is about the limit. Why anyone would want crop to that extent I have no idea. Thanks Jerome It is not able to accept a VGA signal just composite. VGA is something that I haven't looked at. I don't build or sell any so I have no idea of cost. Forum member Freya does build them he should be able to let you know the cost. I don't think he has a web site. Frank
#14 |
Thanks Frank,
The crop, combined with presets, will make it so much easier to watch freeview - until now the only option was to record program, edit to remove black bars, then re-encode. TTFN, Jon |
#15 | |
![]() Quote:
by using a programme called WinModelines. Here is my system working with a Windows 10 computer with an ATI Radeon HD 2400 XT card. These are available for about 10 Euros on ebay, and you only need to build a modulator. https://youtu.be/ahzdx4KgWBg I just tried an 819 line modeline which came from Semir_DE Linux project https://www.vintage-radio.net/forum/...d.php?t=167674 (It's much simpler with Windows) and I get this result on my 405 line set, the two side-by-side pictures exactly as we got the French Sporadic-E interference in the 1960s!
-- Graham. G3ZVT Last edited by Graham G3ZVT; 19th Jan 2021 at 3:17 am. |
#16 |
Hi Jon
The Hedghog and Hedghog II can crop the bars out too. The amount they crop is set and cant be adjusted like the Hedghog PSC. Hi Graham The PC method looks to give good results. I haven't tried it yet. Hopefully one day I will get around to it. Frank
#17 |
How much is the Hedghog PSC?
#18 |
Has anyone tried running a vintage home computer through a hedgehog? I wanted to run my Amiga's composite output to it but it refuses to sync.
33, 45, 78, around and around they go...
#19 |
Hi guys. I have been trying to use my old Amiga 500's composite out to feed my hedgehog into my TV22 but it won't sync. Any ideas?
#20 |
I have tried running an old Nintendo Entertainment system through mine, and it refuses to sync, I also tried on the Aurora and that also refused to sync, so I guess there is something a bit rubbish about the signals these types of old computers create, a normal TV copes with it fine, but standards converters do t like it!
Regards Lloyd |
