Old 13th Jan 2021, 11:40 am   #1
Ian - G4JQT
Ian - G4JQT's Avatar
Default Component wax
Is the wax used on coils etc. ordinary bees wax? I have some wound components that I want to to tidy up and re-dip. In the past I've used candle wax diluted with a little olive oil (!) as it sets too hard and flaky otherwise, but I doubt that's an ideal combination.
Thanks
Ian
Ian - G4JQT is offline
Old 13th Jan 2021, 1:17 pm   #2
G.Castle
Default Re: Component wax
Bees wax is good. It does need to have the moisture driven out for electrical use by heating to just about melting point, (dont overheat!), and kept at that temperature for a couple of hours.
Beeswax is firmer than candle wax, and will withstand higher temperatures, paraffin wax or tallow isn't ideal for electrical work.
G.Castle is offline
Old 13th Jan 2021, 1:20 pm   #3
Julesomega
Julesomega's Avatar
I assumed it was paraffin wax owing nothing to bees. I wonder if that wax used to cover individual small cheeses is a suitable substitute - it comes in several colours
- Julian
It's good here
Julesomega is offline
Old 13th Jan 2021, 1:24 pm   #4
G.Castle
Softens at very low temperatures and has a high moisture content, probably just refined tallow.
G.Castle is offline
Old 13th Jan 2021, 2:05 pm   #5
I got SWMBO a candle making kit for Christmas, it contains soy wax, I wonder if that would be better?
Old 13th Jan 2021, 3:22 pm   #6
G.Castle
Originally Posted by merlinmaxwell View Post
I got SHMBO a candle making kit for christmas, it contains soy wax, I wonder if that would be better?
The fumes will be less dangerous to breathe with the soy wax when the component it's coating finally burns up....
G.Castle is offline
Old 13th Jan 2021, 10:58 pm   #7
regenfreak
Oil based polyurethane varnish? It is water repellant and harden well to fix coils. It is known not to affect the Q much. Buy a cheap set of small paint brushes from a pound shop as the brush has to be thrown away for single application.
regenfreak is offline
Old 13th Jan 2021, 11:16 pm   #8
suebutcher
suebutcher's Avatar
Carnauba wax? An artist friend gave me a block of this he'd used for modelling. It's good for recoating old components because it's stickier and more flexible than paraffin wax.
The Waves That Rule Britannia
suebutcher is offline
