Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 20th Nov 2020, 6:37 am   #1
Uncle Bulgaria
Uncle Bulgaria's Avatar
Default Adding Greek letters to posts.
Split from this thread:-
https://www.vintage-radio.net/forum/...d.php?t=173296
Even more technically, if you want to write µ it's Alt + 0181 on Windows! I can thank this forum for telling me that.
If it's not the motor, it could be one of the components you mentioned on the armature. Check those capacitors for leakage at the rated voltage.
Uncle Bulgaria is offline
Old 20th Nov 2020, 11:54 am   #2
DMcMahon
DMcMahon's Avatar
Default Re: Motorola 251 8 Track Motor Resistor Burn Out!
Thank you Uncle Bulgaria, I did know that but for some unknown reason when I try it in a Forum new message (OK elsewhere) when I type 1 it exits the message ?
DMcMahon is offline
Old 20th Nov 2020, 11:56 am   #3
ms660
ms660's Avatar
Same here, tried a few times, no go.
Lawrence.
ms660 is offline
Old 20th Nov 2020, 12:11 pm   #4
Station X
Station X's Avatar
Assuming you're using a PC you need to use the numeric keypad, not the keys along the top of the keyboard.
µµµµ
The character appears when you release the ALT key.
Graham. Forum Moderator
Station X is offline
Old 20th Nov 2020, 12:21 pm   #5
DMcMahon
DMcMahon's Avatar
Thank you Graham, now working on PC.
µµµ
DMcMahon is offline
Old 20th Nov 2020, 12:29 pm   #6
ms660
ms660's Avatar
Cheers for that.....µ....
Just need Pi and squared and cubed now without trawling through some endless character map....anyone?
Lawrence.
ms660 is offline
Old 20th Nov 2020, 12:43 pm   #7
DMcMahon
DMcMahon's Avatar
Alt 0178 and 0179.
Pi is supposed to be Alt 227 but no good for me.
DMcMahon is offline
Old 20th Nov 2020, 1:18 pm   #8
Refugee
Refugee's Avatar
You need an old DOS 6.2 paper manual.
They used to have a full list at the back.
Refugee is offline
Old 20th Nov 2020, 3:04 pm   #9
Uncle Bulgaria
Ah, sorry! I forgot to mention the numpad bit. I was reading up on this the other day when I wanted to write 'pi' when Lawrence was explaining screen grid losses. I had the same experience as you, David: it doesn't work, and the character map has no Alt code for pi for whatever reason (UK keyboard, Windows 10...)
However, a post on the Windows board revealed that Alt codes are not considered part of modern Unicode setups, with hex codes being preferred. In my character map, a small pi is U+03C0. We need to make sure all Unicode characters are allowed, so we have to add a string to the 'input method' in the registry at HKEY_CURRENT_USER\Control Panel\Input Method.
Under Input Method we create a new string with the name EnableHexNumpad; double-click on it in the right-hand pane and change its value to '1'. After a restart, I can use the left Alt as the 'U' in U+03C0 and type π.
Caveats: the '+' is required as a keypress, unlike in the Alt code where it represents holding down the Alt key while typing the numbers, although holding down the Alt for the duration of entering the code is required. The initial zero is not required though. Thus holding down Alt and typing +03c0 or +3c0 results in the same output of pi. One can use this for any Hexcode entry in the character map (obtainable swiftly in Windows 10 by pressing the Windows key and starting to type 'character map'. For me it pops up as soon as I type 'C', perhaps because I've done it a few times!)
Anyway, after that swoop through the registry I'll stop before the Motorola is entirely lost in the dust.
Old 20th Nov 2020, 3:20 pm   #10
ms660
ms660's Avatar
Alt 0178 and 0179.
I tried all of those on the number pad but as soon as I press 7 the PC screen goes to Google search.
Lawrence.
ms660 is offline
Old 20th Nov 2020, 3:25 pm   #11
DMcMahon
DMcMahon's Avatar
That is a shame it works for me
X² Y³
DMcMahon is offline
Old 20th Nov 2020, 3:32 pm   #12
DMcMahon
DMcMahon's Avatar
Followed the instructions but struggling to get Pi to work.
DMcMahon is offline
Old 20th Nov 2020, 3:48 pm   #13
ms660
ms660's Avatar
Default Re: Adding Greek letters to posts.
X² Y³
I tried again in the reply box on this forum to be sure ....as soon as I press 7 the screen goes to Google search but if I carry on and complete the number sequence then let go of Alt then the resulting symbol eg: the one for squared or cubed, is displayed in the Google search box
Lawrence.
ms660 is offline
Old 20th Nov 2020, 6:31 pm   #14
Magical
Well, this is all well and good, but in the meantime my 8 track is smouldering away in the corner ;-)
Thanks for the tips on u....I’m on my iPad now so no idea how to get a proper u symbol up. Anyone?
Magical is offline
Old 20th Nov 2020, 6:34 pm   #15
Magical
Will do Uncle Bulgaria
Magical is offline
Old 20th Nov 2020, 6:55 pm   #16
kalee20
If using the numeric keypad on a modern keyboard, try hitting NumLock first.
Also: Some programs, Alt-919 gives Ω, sometimes Alt-937.
For μ it's alt-931 or alt-956
For π, alt-935 or alt-960.
kalee20 is offline
Old 20th Nov 2020, 7:16 pm   #17
ms660
ms660's Avatar
Still can't get it to work, keeps going to Google or another page on UKVRR as soon as I press 7 or 9 respectively on the number keypad
Only way is when it goes to Google and displays the result of entering Alt+0178 into the Googles search box is to cut and paste it from there
Got a feeling that Google and Windows 10 have a problem at the moment.
Lawrence.
ms660 is offline
Old 20th Nov 2020, 7:30 pm   #18
We could try content over style and simply spell out the required.
Old 20th Nov 2020, 7:52 pm   #19
Nuvistor
Nuvistor's Avatar
Αdd the Greek keyboard. Settings/General/Keyboards/Add New Keyboard select the Greek one. Choose which keyboard to use with the Globe sign on the bottom left of the keyboard.
Ω μ η θ α β Etc .
Frank
Nuvistor is offline
Old 20th Nov 2020, 7:54 pm   #20
ms660
ms660's Avatar
I normally that's what I have done and hope that folks that read my posts understand, but I would like to use the proper symbols without scrolling through reams of symbols in a character map or having to do a semester on how to use a computer.
Lawrence.
ms660 is offline
