Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 28th Oct 2020, 9:20 am   #1
kelvinmunson
kelvinmunson's Avatar
Default Garrard SP25 Power Switch
Good morning
I am looking for a replacement power switch for an SP25 Mk2., part no 70548/03, as the contact breaker inside mine has fatigued and broken off.
Any suggestions for possible sources for Garrard spares would be very much appreciated.
kelvinmunson is offline
Old 28th Oct 2020, 10:34 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Garrard SP25 Power Switch
Fitting an industry standard V5 microswitch is what I would do.
Nickthedentist is offline
Old 29th Oct 2020, 6:29 am   #3
Diabolical Artificer
Diabolical Artificer's Avatar
Pic? SPST, DPDT? I have loads of micro switches etc some more would help not being familair with Garrard SP25's or part #'s.
Andy.
Old 29th Oct 2020, 8:30 pm   #4
cliff2903
Is it this one??
cliff2903 is offline
Old 29th Oct 2020, 10:15 pm   #5
Techman
Techman's Avatar
This is a common problem and a 'stock fault' on all this series of decks, so any 'old' replacement switch you get will probably be not far off failing again anyway. What I do is repair the original - I posted some info with a couple of pictures several years ago regarding this. The other option is to modify the mechanism/mounting to take a micro switch.
Techman is offline
Old 29th Oct 2020, 10:29 pm   #6
Techman
Techman's Avatar
Just found pictures of the repair/bodge. Basically solder on some copper shim to bridge the break and reinforce the broken part. You'll need some needle files and you may need to remove a bit of the plastic.
ID:	219188   Click image for larger version
ID:	219189   Click image for larger version
Techman is offline
Old 30th Oct 2020, 7:10 am   #7
kelvinmunson
Yes, that's the one. Thank you for the advice
I will have a go at carrying out the repair suggested and if that doesn't go wello I can obtain a suitable Microswitch and modify the base to suit.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
