Old 28th Jun 2020, 3:59 pm   #1
Robert Gribnau
Robert Gribnau's Avatar
Default Guitar amplifier with 2 x EL86 push-pull
Hello all,
I have just finished and tested the electronic part of a guitar amplifier. All that is left to be done, is making and installing the bottom plate (MDF with an aluminum cover on the amplifier side as a screen).
Because the figures for a pair of EL86's in push-pull are a little bit better than those for a pair of EL84's in push-pull, I wanted to build an amplifier using EL86's for some time now.
One of the design problems was to keep the needed 200 V supply voltage for the screen grids of the EL86's constant (enough) while the anode supply voltage has to be 250 V. The screen current varies from 4 mA (no signal) to 26 mA (full power). Dropping the 250 V to 200 V with a resistor would cause to much voltage sag. But by using two ZZ1040 voltage stabiliser tubes i solved this problem.
The amplifier works very well. No noise at all with the volume turned down and very loud when turned up. And the ZZ1040's give off a lovely bright-purple glow which diminishes a bit when you give the guitar a good 'hit'. I can not wait to see how it will look after sundown.
Edit: Because the schematic is hard to make out, a link to the schematic on my internetsite: https://1.bp.blogspot.com/-SwqQZAEWU...600/Schema.png
Greetings,
Robert
ID:	209733   Click image for larger version
ID:	209734   Click image for larger version
ID:	209736   Click image for larger version
Robert Gribnau is offline
Old 28th Jun 2020, 4:52 pm   #2
GrimJosef
Default Re: Guitar amplifier with 2 x EL86 push-pull
It's nice to see the EL86 getting some use. They are quite plentiful and cheap compared with the EL84. It is slightly ironic that that your stabilised screen grid supply doesn't use another EL86. One of the things they were designed for was to act as the pass valve in stabilised HT supplies .
Cheers,
GJ
http://www.ampregen.com
GrimJosef is offline
Old 28th Jun 2020, 6:35 pm   #3
I like the "If it is still glowing you are not playing loud enough" indicators!
Old 28th Jun 2020, 7:16 pm   #4
Robert Gribnau
Thanks GJ, Merlin.
It was the combination of the available chassis and available power transformers that made me not use a pass valve for the screen grids. The maximum currents for the two high tension windings are 120 mA and 60 mA.
About the indicators: The more Deep Purple they glow, the better?
Greetings,
Robert
Old 30th Jun 2020, 1:32 am   #5
retailer
Excellent job - well done I'm sure you get a lot of enjoyment out of using it.
I did a conversion from PP El36 Philips PA amp to guitar amp around 10 years back, my son still has it and at times uses it for recording so I guess it can't be all that bad.
I know you have your circuit "sorted out" but just as a matter of interest the power supply was a regular transformer with ct HV winding, and a bridge rectifer - ct was used for the screen supply as in the attached circuit, the 6DQ6 is also a TV valve..
retailer is offline
Old 30th Jun 2020, 6:08 am   #6
Robert Gribnau
Thanks.
Sounds familiar. A picture from 2007 when I was running my guitar stereo through a 2 x EL84 pp amplifier and a 2 x EL36 pp amplifier.
Greetings,
Robert
Name:	Philips HF10 & Philips EL6405 & Boss ME-50.jpg
Old 30th Jun 2020, 6:41 am   #7
SeanStevens
SeanStevens's Avatar
I wish you were my neighbour - as a guitarist I'd offer to soak test the amp for you!
Looks excellent
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
Old 30th Jun 2020, 8:54 am   #8
Robert Gribnau
Thanks.
I wonder if my other neighbours would like that idea. One home musician in the block is probably enough as it is for them. But I only play between 12:00 and 18:00 hours (i also picked up electronic drumming and keyboard) and that is going fine.
Greetings,
Robert
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
