| General Vintage Technology Discussions For general discussions about vintage radio and other vintage electronics etc. |
#1 |
Philips210 asked for some information on Philips code numbers in https://www.vintage-radio.net/forum/showpost.php?p=1225464&postcount=6
Since such questions come up from time to time, it may be better to answer them in a common thread. Requests for information or explanation can also be posted here. The 12NC coding system was implemented starting in 1963 and is still in use in some Philips and former Philips locations. It was thought up to reflect the matrix business model that Philips used to have but is quite versatile and well thought out. Last edited by Maarten; 15th Mar 2020 at 1:15 am. |
#2 |
The first two digits are called "code group" and started out corresponding to a main industry group or industry group so they indicate the kind of product the number refers to.
The interpretation of the remaining 10 digits is determined by the code group, even though the meaning is relatively consistent between code groups. Code groups 01 through 82 mostly follow the same pattern, with the exception of 48 and 53. Code groups from 85 through 98 are commercial numbers, what we would call SKU's in modern jargon and may or may not follow similar patterns. Most relevant for this forum are code groups 31 for consumer electronics (originally main industry group "radio, gramophone and television") 35 for telecom 39 for electro acoustics 40 for professional electronics 42 for appliances and large appliances 46 (later) for large appliances 48 and 53 for service parts (not an industry group but straight under the core organisation) 85 (later) for large appliances 86 and 90 for consumer electronics 88 for appliances and large appliances 95 for telecom Last edited by Maarten; 15th Mar 2020 at 1:42 am. |
#3 |
The third and fourth digits are called "coding centre". This often corresponds to a national organisation (read: country), but can be a product group or business unit (I don't know the official jargon for that case).
These numbers also correspond to the first two digits of model numbers as often used (but sometimes omitted) from 1966 on. This is because the model number corresponds/maps to the SKU and the SKU is a 12NC. Though it often correlates, this is NOT meant to indicate the country of manufacture! Rather, it indicates the origin of the design or of the commercial specification (especially in SKU's). It started out as an alphabetical listing (with some flaws in bold, if anyone knows why, I'd like to know), but as national and other organisations were added, the assignment happened in order of appearance. Numbers up to and including 37 were taken from a 1967 internal list from Philips. I haven't spotted all of them in the wild. Some may have never been used or only used much later (I'm not aware of any Polish activity before 1989, though Philips might have had some kind of organisation in Yugoslavia). 01 Argentina 02 Australia 03 Austria 04 Belgium 05 Colombia 06 Brasil 07 Canada 08 Denmark 09 Chile 10 Finland 11 France 12 Germany 13 Great Britain 14 Greece 15 India 16 Indonesia 17 Nigeria 18 Ireland 19 Italy 20 Japan 21 Mexico 22 Netherlands 23 New Zealand 24 Norway 25 Peru 26 Salvador 27 Polen 28 Portugal 29 South Africa 30 Spain 31 Sweden 32 Switzerland 33 Turkey 34 Uruguay 35 USA 36 Venezuela 37 Yugoslavia 38 Taiwan 39 Singapore 40 Hong Kong 41 China? 42 China? 43 Hungary Then some higher numbers were assigned mostly used for audio related stuff, often seen in SKU's and not often in the lower numbered code groups. 66 (seen on hifi from Sweden) 67 (seen on a portable radio from Japan) 69 (seen on various car radios) 70 (central product range from Eindhoven, still in use) 74, 75 Marantz 90 Far East (seems to have also been used for Singapore before 39 was assigned and for Hong Kong before 40 was assigned) Last edited by Maarten; 15th Mar 2020 at 1:51 am. |
#4 |
Maarten, from what I know, the following was used:
countries: 41 Peoples Republic of China 42 Republic of Korea 44 Romania Jac |
#5 |
Thanks Jac, that's a very good addition!
#6 |
Thread reopened by request.
#7 |
As an addition to post number #2, I'll list the code groups (1st and 2nd digit of the 12NC) below 30 as they were in use in 1967. Those code groups aren't tied to industry groups or business units, but to basic product categories instead.
01 Iron, steel and alloys 02 Nickel, chrome, kobalt and alloys 03 Copper, noble metals and alloys 04 Light metals and alloys 05 High melting point metals and alloys 06 Welding and soldering materials, low melting point metals and alloys 07 Insulated wire, cables, cords 08 Plastics and rubber 11 Glass and ceramic 12 Various non-metallic materials 13 Chemicals, paint 19 "verbindingen en tulen" (connections and cable feedthroughs *) 20 capacitors - 3rd party production 21 resistors - 3rd party production 22 capacitors - own production 23 resistors - own production 24 various electrotechnical and electromechanical articles 25 fasteners 26 machine parts, machines, tools 27 building blocks for electrical app. 28 facilities, transport, packaging 29 building materials, hinges and locks *) tulen or tules are longer, often flexible plastic or rubber, cable guides used where the cable enters the connector or apparatus. It can be translated to cable gland but I think feedthrough is more accurate. Is there a better word for that? Last edited by Maarten; 4th May 2024 at 8:26 pm. |
#8 | |
Chris
#9 |
I'd think the strain relief is the part that clamps down on the cable, at least the literal equivalent part in Dutch 'trekontlasting' does that.
#10 |
In the code groups 01 to 82, with the exception of 48 and 53 and most notably the loudspeakers coded in the 24 group, the 12th digit is usually a revision number.
This means that it may be different but if that's the only digit that's different, the parts are mostly interchangeable. I don't intend on posting about the 5th through 11th digit in more detail anytime soon, but (again for groups 01 through 82 except 48 and 53) the 5th and 6th digit would often indicate the location (e.g. factory) within the coding centre where the number was originated and especially with coding centre 31, the 7th and 8th digit would indicate an article group (for example 8 3 for transformers). I'm mentioning this especially because the meaning isn't aligned with the usual spacing of the numbers. |
#11 |
Hello,
this may be a silly question: Is there an official publication or website by Philips themselves on that coding system? I'm asking because e.g. Siemens Germany - in the good old days - had lots of printed internal publications on their abbreviation jungle and numbering systems, so why wouldn't Philips do so as well? Joe |
#12 | |
#13 | |
Originally it was envisaged that the records would be scanned and computer files created but the cost was prohibitive so it was quietly dropped. I imagine that's happened to a lot of company's. Cheers Mike T
Invisible airwaves crackle with life or at least they used to ![]() Mike T BVWS member. www.cossor.co.uk |
#14 |
Philips probably still has lots of information, but it would likely be somewhat fragmented and mostly unpublished/inaccessible.
I have built my own database (of >15000 non-unique 12NC and >7000 non-unique old codes) from observations and sometimes fragments of information. Part of the information in this topic was verified against and derived from a double sided A4 sheet that was published internally by Philips ELA (electroacoustics) in 1967 to help users understand the somewhat newfangled system (it was first introduced in 1963, by 1967 most divisions would have largely switched over to the 12NC system). |
