13th Feb 2020, 2:23 pm | #1 |
RCA 5T5 How to remove tuner knob?
Dear all,
I was wondering how could I remove the tuner knob of a RCA victor 5T5 model. (please see attached image). The other knobs were removed with a simple pull. Does the tuner knob work similar, or is there a screw somewhere? I don't want to force when pulling without making sure that there are no screws holding it. Any help will be much appreciated. Thanks in advance, Diniz from PORTUGAL |
13th Feb 2020, 2:37 pm | #2 |
Re: RCA 5T5 How to remove tuner knob?
Hi Diniz Can you have a look inside the set? I once had a different set with a retaining clip inside. It had to be squeezed together to remove knob. This was only on the tuning knob.
I hope this helps, John.
My favourite text message "I'll be there in five minutes, if not read again" |
13th Feb 2020, 2:57 pm | #3 | |
It is not easy to take a look from the inside of the set, because there is a metal plate covering that part. But please see attached images. Thanks, Diniz |
13th Feb 2020, 3:39 pm | #4 |
It might be worth while going on www.antique radio .com, the USA radio site and asking the same question, before you go any further..
I have a later RCA radio/record player and the knobs on that are all held with spring clips and are very hard to remove. Mike. |
13th Feb 2020, 5:38 pm | #5 |
Nothing obvious in your photos, best follow Mike's advice.
John.
14th Feb 2020, 8:17 am | #6 |
It looks like the tuning knob is a dual concentric type. In which case the centre knob will have to come off first.
I have found these types of knob normally have a grub screw on each of the knobs. Look carefully it may be disguised and filled with hard wax. Mike |
