Old 19th Dec 2019, 11:41 pm   #1
Dekatron's Avatar
Default Teaser on what a new AVO VCM163 meter can look like!
Finally some progress on new AVO VCM163 meters!
Solving the knob, shaft and movement of the adjustable scale has taken for ages, but I finally have a solution that I can show you how to do yourself, I will write about this in an article that I am putting together right now.
The same article will also contain the information on the AVO VCM Mk III, Mk IV and CT160 (A) meters and the LED-drivers for the overload relay.
Stay tuned!
Happy Christmas and a Happy New Year to you all!
/Martin
ID:	195622   Click image for larger version
Martin, Sweden
Dekatron is offline
Old 20th Dec 2019, 12:16 am   #2
Craig Sawyers
Craig Sawyers's Avatar
Default Re: Teaser on what a new AVO VCM163 meter can look like!
We're tuned, Martin! Looking forward to your write up.
Have a great Christmas and Happy New Year
Craig
Craig Sawyers is offline
Old 20th Dec 2019, 1:12 am   #3
Bazz4CQJ
Bazz4CQJ's Avatar
Sounds like you have been very busy Martin; look forward to learning more.
B
Data beats opinions most times... that's my opinion, though I have no data on that.
Bazz4CQJ is offline
Old 20th Dec 2019, 10:02 pm   #4
sven_swe
sven_swe's Avatar
This meter looks better than the original! Very nice work!
Happy holidays
sven_swe is offline
Old 22nd Dec 2019, 1:18 am   #5
Dekatron's Avatar
Here's what it looks like on the front panel with some extra LEDs used for the overload circuit, you don't have to add them if you don't want to, they are optional of course.
Now, this is only one of my prototypes but it works as it should even though this one is missing the adjustable scale (I am waiting for some parts in the mail to finish this prototype).
To get the meter to fit properly in the front, without covering any of the text below it, won't be an easy job. You'll either have to cut the Simpson meter case at the back or you'll have to cut the front panel, this as the protruding part housing the movement sits "higher" up on the Simpson meters than on the original ICE meters AVO used, resulting in the bottom edge of the case sitting lower. You can see what it looks like in the second photo with a cut meter housing, it is just possible as the magnet for the movement is somewhat flat on the top and smaller than the housing. You'll have to cover this part with something and I am planning on making some small pieces of thin circuit board that can be soldered to each other and then glued or taped in place. Making the cuts is quite hard as the plastic resembles Bakelite, if it isn't in fact Bakelite - I don't have any information on that right now.
If I can find a broken original ICE meter for the VCM163 I could try to make a kit to mount a Simpson movement inside the original housing but right now I don't have any broken ICE meters for the VCM163 - but if someone would be willing to give me a broken one I could try using that one, I can't guarantee that it will work but will give it my best try.
/Martin
ID:	195685   Click image for larger version
Martin, Sweden
Dekatron is offline
Old 22nd Dec 2019, 11:31 am   #6
Sinewave
Sinewave's Avatar
I wonder if the same could be done for the Avo CT38 movement?
Avometer, vintage Fluke and Marconi collector.
At 144-146.00Mhz, keeping one wavelength apart.
Sinewave is offline
Old 22nd Dec 2019, 11:34 am   #7
Dekatron's Avatar
Iím not familiar with the CT38, but if you have some measurements of the meter I can have a look.
/Martin
Martin, Sweden
Dekatron is offline
Old 22nd Dec 2019, 11:50 am   #8
Sinewave
Sinewave's Avatar
I could be wrong, but I 'think' they're the same movements?
Sinewave is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
