Old 21st Aug 2019, 2:26 pm   #1
ssnjimb
Default Ferguson 3V55 Videostar VCR
Hello
I have an Ageing 1985 Ferguson Videostar 3v55
It no longer takes the tape in onto the drum
Can anyone help me source a service kit etc etc
Thankyou in advance
James
ssnjimb is offline
Old 21st Aug 2019, 3:10 pm   #2
toshiba tony
toshiba tony's Avatar
Default Re: Ferguson 3V55 Videostar VCR
Used to see a lot of Thorn stuff. I'm sure lacing, as it's called, takes place via a worm gear and standard belt and motor. I assume it accepts a cassette and it's lowered ready for lacing. If I remember correctly the belt is accessed from underneath and may necessitate the deck being removed. Access my be given by removing the bottom cover, as on the 3v29\30. They are an engineer friendly machine. After the cassette is taken in can you hear a motor whirring as if there is no load on it?
toshiba tony is offline
Old 21st Aug 2019, 3:19 pm   #3
toshiba tony
Just looked at the loading motor for the 3v55. Apparantly the lacing is not belt driven. The info I gave you earlier is for a previous deck. I'll look for the exploded view of the mech.
Old 21st Aug 2019, 3:20 pm   #4
HamishBoxer
HamishBoxer's Avatar
As there is no loading belt then it could be grease starting to harden.
G8JET BVWS Member and V.M.A.R.S
HamishBoxer is offline
Old 21st Aug 2019, 3:44 pm   #5
toshiba tony
Exactly, if it is grease then a CP may have failed as well. Thorn stuff tended to be full of them, they often failed for no reason. If the original poster is at all ok with electronics he could meter the voltage on the loading motor when loading takes place. To ex engineers it's a doddle. At least it's not one of those horrible ones with a SMPS. They didn't scare me. 3V31
No wrong model, anyone?
29 no
30 no
35 no
31\32 no
Old 21st Aug 2019, 4:09 pm   #6
ssnjimb
I will dissasemble the cassette mechanism (spring loaded) and look underneath it. and remove the panel from underneath and report back tomorrow afternoon.
p.s what is a cp ahaha. is it something obvious once you tell me
Thankyou
James
ssnjimb is offline
Old 21st Aug 2019, 4:23 pm   #7
toshiba tony
Hiya, it's the circuit reference Thorn use. Circuit protector, or as we call it a fuse. It looks like a transistor but the give away is it only has two legs.
Old 21st Aug 2019, 4:57 pm   #8
ssnjimb
A diagram would be great if. if you have one.
is it rubber tyres on idlers per chance.
Thanks
James
ssnjimb is offline
Old 21st Aug 2019, 5:55 pm   #9
toshiba tony
It seems from the poster lacing isn't starting so at this stage the reel idler (if fitted) will not be employed. Does the drum rotate at any stage? On vcr's of most makes the mech usually shuffles in both directions, probably to check if the tape has snapped. If either reel goes too fast the vcr will detect this and eject the cassette. Another reason the mech shuffles is to prepare the tape for lacing, (no possible slack).
Old 21st Aug 2019, 7:05 pm   #10
vhs doctor
Hi
If the loading motor rotate.Change the loading belt it is loxated behind the pinch roller.
If the problem still exist maybe you have broken gear.
vhs doctor is offline
Old 21st Aug 2019, 7:47 pm   #11
toshiba tony
Right vhs doctor, so this model has a loading belt? looking at the shaft on the motor suggested otherwise as it's not got a pulley on it! I was working from memory on my first post thinking it was similar to a 3v29\30
Old 21st Aug 2019, 7:53 pm   #12
ssnjimb
I need a belt then. Can they still be bought ? is it thin like a walkman belt ?
The VCR is at my parents hence the questions.
James
ssnjimb is offline
Old 22nd Aug 2019, 6:47 pm   #13
vhs doctor
Vcr belts usually they are not thin as walkman belts.
Check this
https://m.donberg.ie/descript/7/7076.htm
Old 23rd Aug 2019, 12:16 pm   #14
dj_fivos_sak
Hi. The original JVC part number for the loading belt is PQM30003-14. If you don't hear the motor running when you press play, you might have a missing PSU voltage or one or more ICPs have blown. It's a common issue with these JVC machnes and has happened on my HR-D110 (3V38) and HR-D120 (3V35).
dj_fivos_sak is offline
Old 25th Aug 2019, 6:24 pm   #15
ssnjimb
Thankyou
I will report back when i get it working
James
ssnjimb is offline
Old 30th Aug 2019, 12:30 pm   #16
ssnjimb
Hello
After cleaning the front panel/LCD/etc
Unplugging all the connectors inside.
It takes the tape in.
Starts playing for 3 seconds.
albeit with a slipping clutch
It then stops after 3 seconds playing.
Is that the optical switch ?
James
ssnjimb is offline
Old 30th Aug 2019, 1:37 pm   #17
toshiba tony
Does lacing take place, (and complete?) Do you briefly see a picture? Lack of take up reference pulses will initiate stop. What is rewind and FF like. Does the drum turn? After lacing does the LM stop, that suggests lacing has occurred corectly. Select pause straight after lacing has completed, Does the tape remain laced. Ability to use a scope would be a great help. Pulses should be checked. Particularly FG and PG pulses.
Old 30th Aug 2019, 1:54 pm   #18
ssnjimb
It fully laces and the tape starts moving (top cover removed. drum spins. the LM stops fully. and yes a picture briefly appears. I will try pausing straight after lacing.
The VCR is now at my Girlfriends.
Great Progress
Mine is a 1986 UK built version.
James
Name:	2019-08-28 16.21.50.jpg
ssnjimb is offline
Old 30th Aug 2019, 2:10 pm   #19
toshiba tony
Right, getting there, I have dementia but I follow your symptoms. As I've said, as soon as lacing finishes hit Pause and report back. We are nearly there.
Tony Walker
Old 30th Aug 2019, 9:38 pm   #20
John123
Try put the lid back on for initial testing as the deck may be light sensitive.
Regards,
John
John123 is offline
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
