Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 14th Aug 2019, 6:29 am   #1
Electronpusher0
Default New Posts search does not find replies to own thread
I have missed a couple of replies to threads I started.
Usually I check the threads regularly but once they have gone quiet I sometimes forget to check back.
I have been relying on the "New Posts" search to find any late posts but have discovered that this search does not show any replies to a thread I have initiated.
Is this normal behaviour?
Peter
Electronpusher0 is offline
Old 14th Aug 2019, 6:45 am   #2
John M0GLN
John M0GLN's Avatar
Default Re: New Posts search does not find replies to own thread
It's the same for me, I've always assumed it's the way the forum works, but I do get an email notification every time there is a reply to a thread I've posted in, in the 'additional options' box just tick the 'instant email notification'.
John
John M0GLN is offline
Old 14th Aug 2019, 10:31 am   #3
Electronpusher0
Thanks John, I'll try the e-mail option.
Peter
Old 14th Aug 2019, 1:41 pm   #4
Station X
Station X's Avatar
I assume by ' "New Posts" search ' you mean clicking on the "New Posts" button?
This should return all threads in which there are posts which you haven't read.
However if you were the LAST member to post in a thread, then that thread won't be listed.
Graham. Forum Moderator
Station X is offline
Old 14th Aug 2019, 5:24 pm   #5
Electronpusher0
Yes I was refering to the "new posts" button and it definately does not show new posts to a thread I have initiated, even posts from other members.
For example your reply quoted above did not show when I pressed the "new posts" button.
Peter
Old 14th Aug 2019, 6:00 pm   #6
AC/HL
AC/HL's Avatar
As John says, if you select instant notification you'll get an email if anyone (except you) posts in a thread that you have posted in.
AC/HL is offline
