30th Jul 2019, 7:17 pm | #1 |
Drawing circular log scales?
I need to make a circular log scale to replace the missing one on a signal generator but I can’t find any way of generating a software based version.
Is there something I’ve missed? Can anyone help?
30th Jul 2019, 10:56 pm | #2 |
Re: Drawing circular log scales?
I am not aware of software, but have not needed or looked. It is something which may be not too difficult to do by hand. You only really need the length of circle perimeter (or length of the scale if not full circle) then calculate a normal straight log scale to fit that length. Then transfer over. I can see it would be tedious but with the right tools, practical.
Hopefully someone will have done this and know the tricks (or better still - software). One other option would be if someone were able to take an accurate photograph of such a scale from identical model. |
31st Jul 2019, 5:09 am | #3 |
Something like this?
Done with Abacom's Front Designer, all customisable. Change text, rotation, line lengths etc within the program. |
31st Jul 2019, 8:19 am | #4 |
Hmmm... Can't have '0' on a log scale!
31st Jul 2019, 9:48 am | #5 |
That's right. The one I have is a photocopy of an original, it reads from 10 to 100 over an arc of 290° on a diameter of 4.25" (108mm).
I want to produce a drawing so that I can send it off to have one made in etched aluminium.
31st Jul 2019, 11:44 am | #6 |
Removed the 0 and changed it to 290deg scale.
31st Jul 2019, 12:02 pm | #7 |
Thank you! Please could you change it so the marks are on the inside of the arc and reverse it so that 10 is where 100 is? That would be an excellent solution!!
31st Jul 2019, 12:12 pm | #8 |
I've just crudely put a ruler on my monitor face and measure chord lengths: 10-20; 12-24; 20-40; 30-60; 40-80; 50-100 all measure 72mm. so the angles are the same, exactly what would be the case for a log scale!
I like it |
31st Jul 2019, 1:20 pm | #9 |
In principle, that's correct. A real life pot will jump to zero at the end of the track, though.....
1st Aug 2019, 4:17 am | #10 | |
Do you want the arc to remain where it is and the division marks come in from there Or Move the arc to the outside of the division marks as they currently are? And do you want the lines slightly thicker? |
1st Aug 2019, 6:02 am | #11 |
So much for the household chores, started raining and of course it was outside chores.
Attached as first pass depending on which way round you want the changes. Also attached as a pdf as that is nicer than the jpg's. |
1st Aug 2019, 3:01 pm | #12 |
Hi Terry, thank you, it's looking almost right!
I attach a photo of the dial I'm trying to duplicate, I don't know why I didn't do this before....
1st Aug 2019, 3:44 pm | #13 |
You might want to have a play with meterscales, I can't offer any help with the program.
1st Aug 2019, 5:46 pm | #14 |
Thank you, unfortunately I don't have a Windows computer....
2nd Aug 2019, 1:41 am | #15 |
Picture was a good idea.
I'll have a play a little later and see how close I can get it. Are you able to measure the distance between the end of the division mark and the number and the lengths of the marks? |
2nd Aug 2019, 3:00 am | #16 |
There are ways round operating system issues.
This Mac has Oracle Virtual Box installed. This creates a number of virtual machines and I can load any operating system I want on each machine. so I got a legit copy of XP. I can open a window on the Mac OSX screen with XP running in that window, and run windows software on it. David
2nd Aug 2019, 11:13 am | #17 |
This is about as close as i can get it from the picture.
Let me know if it needs any tweaks. |
2nd Aug 2019, 11:37 am | #18 |
Hi Terry, that is fabulous! Thank you, I'll be able to finish rebuilding the signal generator...
2nd Aug 2019, 11:39 am | #19 | |
I have run Virtual Box on the Mac but I don't have a currently licensed version of any Windows system.
2nd Aug 2019, 3:02 pm | #20 |
If you know how to write PostScript, it would take about a screenful of code to produce a scale like that!
If you are running any Unix-like system (i.e., Mac or Linux) then you probably already have GhostScript installed, which is a suite of programs for working with PostScript files including displaying them and converting them to other formats.
