Old 7th Jul 2019, 10:44 am   #1
Ekco-Scott
Ekco-Scott's Avatar
Question Asbestos element former in hair dryers
Hi everyone.
I have amassed a nice little collection of vintage hairdryers I used to use a Ormond/ Siemens one but gave up on it over time as the fact its former was Asbestos began to really get to me.
I know the subject has been discussed here before by other members and a heat proof material board was suggested.
But I had a thought. There is often an abundance of second hand Hairdryers In charity shops etc. Has anyone ever tried using one of the formers from one of these and wrapping the original vintage element on one of these non asbestos formers?
If anyone has had success with it I may attempt it myself. I rather miss using them now as the give a good heat to air ratio unlike modern ones that are far to powerful.
Thanks for your time.
Regards
Ekco-Scott is offline
Old 7th Jul 2019, 4:52 pm   #2
Ekco-Scott
Ekco-Scott's Avatar
Default Re: Asbestos element former in hair dryers
Another thought I had was that if one took a silicone mould of the former you could make an exact copy in cement. Though would it be suitable? Being such a small part a doubt it would and much weight. My only concern would be with the heat cracking the cement. Would that happen?
Old 9th Jul 2019, 9:01 pm   #3
robin0577
robin0577's Avatar
There's a car exhaust repair kit consisting of a glass fibre bandage and some heat cured paste, perhaps you could mould a former from that? a household oven should be hot enough to set it.
"Broken we can fix, cr*p is a design issue"
robin0577 is offline
Old 9th Jul 2019, 10:26 pm   #4
emeritus
Fire cement, as used for installing traditional open fires?
emeritus is online now
Old 10th Jul 2019, 8:08 pm   #5
robin0577
robin0577's Avatar
That was my first thought too actually, but then I thought you'd probably need some kind of reinforcing mesh/fibre as well, which is what led me to think of exhaust bandage.
Old 11th Jul 2019, 1:59 am   #6
Ekco-Scott
Ekco-Scott's Avatar
I shall investigate your suggestions! Thanks for the helpful comments
Regards
Old 11th Jul 2019, 6:18 am   #7
John M0GLN
John M0GLN's Avatar
What shape is the former? Is it flat like a toaster element wrapped on mica sheet or circular with the element wrapped around it in a spiral, have you a photo?
John
John M0GLN is offline
Old 11th Jul 2019, 2:10 pm   #8
Ekco-Scott
Ekco-Scott's Avatar
Hello John.
It is the type that is similar in appearance to ceramic in the shape of an X. I believe it is white Asbestos in a cement or similar substance. The element is wrapped around the x-shaped former.
It's pretty much identical throughout my hair dryer collection. They all have this variety of former weather it is a 30s one or a 50s one.
I whish I had the luck of having found Mica in them but unfortunately not. Mica and similar products are used in the modern one's I've looked at over the years.
Here are some pictures. The model in which the former is from is a mid 50s ormond hairdryer. The model is also made by Siemens as with the white one here also.
Regards
ID:	186485   Click image for larger version
ID:	186486   Click image for larger version
ID:	186487   Click image for larger version
ID:	186488   Click image for larger version
Old 11th Jul 2019, 2:12 pm   #9
Ekco-Scott
Ekco-Scott's Avatar
I should also ad it is the type that is rock hard rather then a soft compressed type
Old 11th Jul 2019, 3:13 pm   #10
evingar
evingar's Avatar
I could certainly see the problem if it was flaky and soft given the air would propel the particles towards you but if it's rock hard I can't see that it would be much of a health issue
Chris
evingar is offline
Old 11th Jul 2019, 3:19 pm   #11
Ekco-Scott
Ekco-Scott's Avatar
My concern is from heating and Cooling Cycles that the surface layer may shed particles of asbestos. If it were possible to get them tested and see if they do shed or not it would put me at ease.
I used to use them every day but I do worry about the possibility of damageing my health or that of my fellow householders.
Old 12th Jul 2019, 12:19 am   #12
Refugee
Refugee's Avatar
That looks like fire clay to me.
It is more commonly seen in radiant gas fires.
Refugee is offline
Old 12th Jul 2019, 6:32 am   #13
John M0GLN
John M0GLN's Avatar
Looking at the photos I would agree with Refugee, unglazed fireclay, where I first worked years ago we used many refractory items of various shapes, sizes and materials none of which contained asbestos, however I can't guarantee it 100% and understand if you are still concerned, if you knew a potter they could probably shape and fire one for you quite easily.
John
Old 21st Jul 2019, 5:12 pm   #14
Ekco-Scott
Ekco-Scott's Avatar
Hello All!
Some of you may have seen this lovely 1934/5 GEC Magnet hairdryer in its original box with instructions and advertising literature for sale online recently. Well it arrived with me yesterday and I disassembled it's casing to see if it contains the dreaded Asbestos.
Much to my immense joy I found that the element former is made of mica! There is also no asbestos washers around the motor as is sometimes found.
I reassembled it and plugged it in through a 5 amp round pin to 13amp adapter and it sprung to life with out a moments hesitation! Probably the first time it's seen power in 50/60 years at least!
There of course was the usual burning dust smell then it settled down to running smell free. I used it this morning and I'm happy to report it dose its job perfectly!
Regards.
ID:	187086   Click image for larger version
ID:	187087   Click image for larger version
ID:	187088   Click image for larger version
ID:	187089   Click image for larger version
Old 21st Jul 2019, 5:15 pm   #15
Ekco-Scott
Ekco-Scott's Avatar
Some more images
ID:	187091   Click image for larger version
ID:	187092   Click image for larger version
ID:	187093   Click image for larger version
ID:	187094   Click image for larger version
