Old 2nd Jul 2019, 8:41 am   #1
Aerodyne
Aerodyne's Avatar
Default EF80 - anyone tried it as an audio amp?
The ubiquitous EF80 (who amongst us doesn't have a pile of these?) but unwanted for most construction tasks. My question is, has anyone attempted to use the valve as an audio amplifier and if so, what were the results?
Tony
Aerodyne is offline
Old 2nd Jul 2019, 8:44 am   #2
merlinmaxwell
merlinmaxwell's Avatar
Default Re: EF80 - anyone tried it as an audio amp?
It will work, just not very high power. A few in parallel push pull will make a nice room heater.
Cats have staff, it's dogs that have owners.
merlinmaxwell is online now
Old 2nd Jul 2019, 8:55 am   #3
paulsherwin
paulsherwin's Avatar
There were hobbyist designs for all sorts of things in the 60s when huge numbers of EF80 pulls became available from scrapped tellies. They're a bit noisy for low level audio use, but you can use them as output valves if you only need half a watt or so.
paulsherwin is offline
Old 2nd Jul 2019, 9:01 am   #4
Sideband
Sideband's Avatar
There was at least one TV that actually did this but the model escapes me....
On Spike Milligan's headstone......I told you I was ill...
Sideband is offline
Old 2nd Jul 2019, 9:11 am   #5
kalee20
I've used one as a leaky-grid detector, works fine (100kΩ anode load), not noticed any tendency to be microphonic.
kalee20 is online now
Old 2nd Jul 2019, 9:34 am   #6
ThePillenwerfer
ThePillenwerfer's Avatar
I did it a few years ago. I wasn't very impressed with the result BUT suspect that the EF80s I had weren't in the best condition.
ThePillenwerfer is offline
Old 2nd Jul 2019, 9:55 am   #7
Tyso_Bl
Tyso_Bl's Avatar
I've done this, they work okay, not exactly a power output valve, prolly my favorite small valve, don't tell the audio lot about them triode strapped, it'll push the prices up!
Adapt, Improvise, Oh Bother.....
Tyso_Bl is offline
Old 2nd Jul 2019, 11:45 am   #8
Refugee
Refugee's Avatar
I have been wondering how well they would work in push pull with a very small mains transformer for background audio service.
I looked at the data sheets and came up with about 2 or 3 whats.
I will follow with interest.
Refugee is offline
Old 2nd Jul 2019, 11:59 am   #9
Peter.N.
I also remember a TV that used an EF80 as a sound output valve, but as usual can't remember what it was.
Peter
Peter.N. is offline
Old 2nd Jul 2019, 1:14 pm   #10
barrymagrec
The Z77 (EF91) which is a B7G version of the same valve to all intents and purposes was used by EMI as 3rd and 4th stage valves in the record amplifier of the TR50 and TR51 tape machines.
barrymagrec is online now
Old 2nd Jul 2019, 3:32 pm   #11
TonyDuell
The HMV 1840 series of TVs used an EF80 as the audio output valve. The 1807 used a Z77 (similar to an EF91 I think).
It's not clear to me if the OP meant using the valve as an audio power output device (to drive a speaker via an output transformer) or an audio signal voltage amplifier. I am pretty sure the EF80 can be used for the latter (as well as obviously the former).
TonyDuell is online now
Old 2nd Jul 2019, 3:48 pm   #12
GW4FRX
GW4FRX's Avatar
When I was a lad I used one as the PA in a 144MHz AM transmitter (the modulator was an ECL80). It did manage several contacts although the output power couldn't have been much. But what a thrill...those were the days.
GW4FRX is offline
Old 2nd Jul 2019, 4:59 pm   #13
G6Tanuki
G6Tanuki's Avatar
I've never used an EF80 as a power-device but _have_ used them as a low-level audio stage in the same sense as EF86.
They're cheap and ubiquitous as 'pulls' from old tellies, so why not experiment
G6Tanuki is offline
Old 2nd Jul 2019, 8:07 pm   #14
Leon Crampin
The EF80 is near enough pin-compatible with the 6BW6 to operate as a plug-in replacement. In a small set such as the KB FB10, it's hard to tell any difference in performance.
Not the best of bodges - but effective in an emergency.
Leon.
Leon Crampin is offline
Old 3rd Jul 2019, 7:50 am   #15
ctc15
Hi All I have used EF80's in a 5-10 stereo amp in place of the EF86 and ECC83 ( the push- pull output used PL508's in place of the EL84's).
The preamp EF80 rang like a bell !! but when replaced with a frame grid EF184 it worked well. Two EF80s triode connected were used in place of the ECC83.
I call this my Tele Amp.
Keith
ctc15 is offline
Old 3rd Jul 2019, 8:02 am   #16
Ed_Dinning
Hi Gents, there were many designs for complete amps, radios etc using EF80's and also EF50's in the magazines of the day.
It would be interesting to see the above amp using a set of nice red EF50's, possibly less micro-phonic as well !
Ed
Ed_Dinning is offline
Old 3rd Jul 2019, 8:08 am   #17
GrimJosef
Originally Posted by ctc15 View Post
... The preamp EF80 rang like a bell !! but when replaced with a frame grid EF184 it worked well ...
The Radford STA100 (a serious hi-fi amp, often used in recording studios) used a pair of EF184s as the phase-splitter.
Cheers,
GJ
http://www.ampregen.com
GrimJosef is offline
Old 3rd Jul 2019, 8:58 am   #18
Peter.N.
The 1807 was probably the one Tony, we serviced a few of those and yes, the Z77 was to all intents and purposes an EF91, so that could have been what was used. I'm sure I did see one with an EF80 though. The valve holders on those sets gave no end of trouble.
Peter
Peter.N. is offline
Old 3rd Jul 2019, 10:51 am   #19
Aerodyne
Aerodyne's Avatar
Just for clarity, I had in mind low-intermediate AF amplifier use for the EF80 (a la EF86). Obviously it couldn't hope to compete with the EF86 directly, but it struck me that as an audio voltage amplifier it ought to work reasonably well. I'm surprised it was used as an output valve, but I shouldn't have been, knowing the 'any port in a storm' approach to TV design in the mid 20th century.
Thanks for all the replies. Some really interesting points made.
Tony
Aerodyne is offline
Old 3rd Jul 2019, 11:33 am   #20
GrimJosef
One of the features of the EF86 was its spiral-wound heater designed to reduce levels of hum in small-signal audio applications. These days it's cheap and easy to implement DC heater supplies for valves in these circuit positions so the EF80's simple 'hairpin' heater geometry wouldn't be an issue.
Cheers,
GJ
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
