Old 22nd May 2019, 8:41 pm   #1
record man
Default Bang & Olufsen
Evening all, i have a beocom 1200 answerphone a 2500 phone and a call blocker any ideas how to connect them together. Many thanks Steve
record man is offline
Old 22nd May 2019, 10:46 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: Bang & olufsen
The Beotalk 1200 appears to be a stand alone answering machine and the Beocom 2500 appears to be a just a phone, albeit a very stylish one.
So my guess is they just need plugging into the telephone line using a double adaptor.
Are you saying that the 2500 has call blocking facilities? I can't see that mentioned online.
Graham.
G3ZVT
Graham G3ZVT is online now
Old 22nd May 2019, 10:53 pm   #3
record man
Hi Graham the call blocker is a stand alone machine connected to the 2500.
Many thanks Steve
Old 23rd May 2019, 9:05 am   #4
Graham G3ZVT
Default Re: Bang & Olufsen
What's the model number of the call blocker?
Perhaps you need to plug the blocker into the telephone wall socket, then plug the phone and TAM into the socket on the blocker using a 2 way adapter.
Graham.
G3ZVT
Old 23rd May 2019, 7:53 pm   #5
record man
It's a CPR 106 call blocker.
Many thanks Steve
Old 24th May 2019, 12:03 am   #6
Graham G3ZVT
I think what I described in #4 will block calls to the phone and the answeing machine if that's what you want.
I've taken a look at the manual for the CPR V.106 call blocker
http://www.exteradirect.co.uk/downlo...-106-model.pdf
and I think I can see a problem implementing it though.
If the blocker as sold in the UK really only comes with a short RJ11-RJ11 lead to connect it to your phone, then you will need to improvise something to share it with a second device.
Have you got a BT style double adaptor and a spare ADSL/VDSL filter?
If so try connecting them like this:
Name:	plug adapter using adsl filter.jpg
If it doesn't work try different permutations of LINE 1&2 and TEL 1&2 as it says in the manual.
If I've misunderstood your problem then ask again, but try and give us a bit more detail.
Graham.
G3ZVT
Old 25th May 2019, 11:44 am   #7
record man
Ok i will give that a go today, many thanks for all your help.
Steve
