Old 29th Apr 2019, 9:09 am   #1
vinrads
Default 1.5Volt supply
I have a Panasonic cassette player used to play my talking books , this uses just one 1.5volt battery , I was thinking could I utilise the 5 volt from the USB socket on the JVC DAB radio/CD player as I play the cassette through this via the jack socket, I supose the question is how to drop the 5volt to 1.5volt?
Mick.
vinrads is offline
Old 29th Apr 2019, 9:47 am   #2
FIXITNOW
FIXITNOW's Avatar
Default Re: 1.5Volt supply
LM317. Can get a kit from ebay cheap I use them for battery valve portables to do the heater current.
FIXITNOW is offline
Old 29th Apr 2019, 9:48 am   #3
lesmw0sec
Assuming that the current draw is within reason, I would have thought an LM317 would do, as it can be adjusted down to 1.2V. Not sure what the minimum input votage is for it though.
lesmw0sec is offline
Old 29th Apr 2019, 11:38 am   #4
pip5678
I have one of those modules from an eBay merchant in China. I've just tested it and will give 1.5V off a 5V supply, claimed current rating is 1.5A but I tested it with no load on a meter.
pip5678 is offline
Old 29th Apr 2019, 12:10 pm   #5
Herald1360
Herald1360's Avatar
Presumably the current draw issue is as relevant to the USB source capability as the LM317? Without a heatsink, a TO220 317 should be OK for about 300mA for 5V in and 1.5V out.
Edit: Looking at the likely module, it should be OK for about an amp with the 3.5V I/O differential. I would think for 1.5A it would need the I/O differential kept very close to the 317 dropout value!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 29th Apr 2019, 12:34 pm   #6
mitajohn
May be this is interesting: https://picclick.co.uk/AC-DC-Regulat...759456400.html
Specs:
Input Voltage :
AC 230V-50Hz 14W
Output Voltage :
DC 1.5/3/4.5/6.0/7.5/9.0/12. OV, 6.0VA(Max)
Regards, John
mitajohn is offline
Old 29th Apr 2019, 12:40 pm   #7
pip5678
The 99p eBay module I have does have a heatsink. Agreed if anything like 1.5A was being drawn the available current from the USB socket would need to be borne in mind!
pip5678 is offline
Old 29th Apr 2019, 7:32 pm   #8
vinrads
Just checked the lm317t min input is 4.2 v so this should be ok with 5 volts in to 1.5 volts out . The cassette player probably uses a DC to DC converter ,the battery lasts a good while ,I think I could just about squeeze the LM317 and other bits in the battery compartment . Thank's for all the suggestions . Mick.
vinrads is offline
Old 29th Apr 2019, 10:46 pm   #9
emeritus
Have you tried measuring the current drawn by the player in its various operation modes? The Philips EL3302 draws a pretty constant current of circa 100mA in play, record, fast forward and fast rewind modes, so a simple wire-wound series resistor of suitable wattage rating to drop the excess voltage was all that was needed to use it from a 12V car battery. They did sell a car kit consisting of a resistor in a ventilated metal box with some leads and a plug for which AFAIR they charged about a fiver in 1969: I made up my own.
emeritus is offline
Old 30th Apr 2019, 8:56 am   #10
vinrads
I did consider that option ,but I would like to fit it inside the battery case hopefully the reg won't get hot maybe a bit warm warm , I think some experimenting is needed ,Mick.
vinrads is offline
Old 30th Apr 2019, 9:21 am   #11
snowman_al
snowman_al's Avatar
Or maybe look at the tiny adjustable DC-DC (buck) converters?
(''Mini DC-DC step down converter volt regulator'' has 4.75 to 23 volts in, 1.0 to 17 volts out, @ 3A, for example. Less than 2.)
Never Leave Well Enough Alone...
snowman_al is offline
Old 30th Apr 2019, 9:25 am   #12
Herald1360
Herald1360's Avatar
Wheeeeeeee!
....__________
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
