Old 7th Sep 2018, 5:54 pm   #1
Focus Diode
Focus Diode's Avatar
Default Stuck on a BRC 1400!
Never thought I could get stuck with one of these sets.
This Ferguson 3645 16" model which landed today was found to have a blown 1.5A mains fuse. Simple I thought, probably a shorted mains filter capacitor or HT rectifier.
Initially I thought the HT rectifier was s/c. Not so as it measured fine when removed. Re-fit it, snip the mains filter. Fuse blows instantly!
Replace the HT rectifier just incase. Same thing happens.
The protection capacitor across the rectifier is ok.
Any ideas? It's of course impossible to make voltage readings with the fuse blowing instantly.
ID:	168910   Click image for larger version
ID:	168911   Click image for larger version
Focus Diode is offline
Old 7th Sep 2018, 6:15 pm   #2
toshiba tony
toshiba tony's Avatar
Default Re: Stuck on a BRC 1400!
I've seen loads of your posts, you are the whizz kid on tv's. Nothing measurable cold? Haven't got the manual to hand but these were the most basic on the mains input side. I'll be watching with interest.
toshiba tony is offline
Old 7th Sep 2018, 6:16 pm   #3
DangerMan
Don't forget there's a heater rectifier (W10) as well as a HT one (W11).... you did change the correct one... ?
Pete
DangerMan is offline
Old 7th Sep 2018, 6:44 pm   #4
Freya
Freya's Avatar
If the heater rectifier is shot then the valve heaters will be much brighter, not sure it would blow the fuse though.
Stephen
________________________
"It`s only an old telly"
Freya is online now
Old 7th Sep 2018, 7:01 pm   #5
Sideband
Sideband's Avatar
I don't know the 1400 but check the simple things first, the switch (may have an internal short), are there any VDR's in the mains circuit? Is the smoothing cap short circuit? Has someone 'been in there' and done something stupid?
On Spike Milligan's headstone......I told you I was ill...
Sideband is offline
Old 7th Sep 2018, 7:11 pm   #6
Focus Diode
Hi there, thanks for your contribution.
No evidence of "Unauthorised" service work.
The switch is OK. Cold checks so far haven't revealed any shorts. Clearly when mains is applied something objects as the mains fuse blows immediately.
I now suspect the main smoothing block. I'll try fitting the NOS replacement when I find it in due course.
Old 7th Sep 2018, 7:11 pm   #7
Philips210
Hi
Looking at the circuit diagram, I'd first disconnect one end of W11, the HT rectifier to isolate HT rails HT1, HT2 and HT3. That should eliminate a substantial amount of the set. If the fuse still blows then possibly there's a heater chain fault.
Regards
Symon.
Philips210 is offline
Old 7th Sep 2018, 7:24 pm   #8
Focus Diode
Excellent suggestion Symon. I'll try that when I get back to the set tomorrow.
Brian
Old 7th Sep 2018, 7:30 pm   #9
DangerMan
True but if the HT rectifier is short and the heater rectifier gets swapped by mistake, the fuse will still blow.
Old 7th Sep 2018, 7:37 pm   #10
Focus Diode
It was definitely W11, the HT rectifier I replaced using a beefy BY127.
Old 7th Sep 2018, 7:55 pm   #11
MickMcmichael
I once got caught out with a similar problem on a Thorn 950.
The system soleniod was was the culprit.
MickMcmichael is offline
Old 7th Sep 2018, 8:50 pm   #12
Focus Diode
Interesting. The fusible resistors are both intact on this set.
Something to look at if the mains fuse continues to blow with the HT rectifier disconnected.
I'll report back tomorrow. Thank you all for your help and contributions.
Brian
Old 7th Sep 2018, 9:15 pm   #13
Ed_Dinning
Hi, how about the good old lamp limiter or variac. That should allow you to get voltage readings without fuses blowing and hopefully trace where the amps are going.
Ed
Ed_Dinning is offline
Old 8th Sep 2018, 9:06 am   #14
Focus Diode
Of course you're right Ed. Will have to dig mine out. Thought being a simple 1400 I'd just plug it in having made the usual cold checks.
Not a good idea as it turned out.
The set was found to have a blown mains fuse. It's uncertain if the set failed in use many years ago or if someone tried it more recently. The person I got it from didn't test it.
So I'll be getting the lamp limiter down later and will look for the multicap while I'm at it.
Cheers,
Brian
Old 8th Sep 2018, 10:37 am   #15
Welsh Anorak
Welsh Anorak's Avatar
Disconnecting the HT south of the rectifier is good advice. I'd also disconnect the solenoid as that can do unusual things.
That's a nice early one you've got there.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 8th Sep 2018, 1:07 pm   #16
Focus Diode
After more tests as suggested above we have first light! Well, actually the second as the very first gave frame collapse due to the PCL805 being bent out of position. Another none original of the unbranded type I note.
The dropper was found to have two o/c sections so was replaced. The mains fuse no longer blew when tried with a lamp limiter. I guess it needed a gentle wake up.
This was the result. S/C W10? I'll replace that next.
Edit- Turned out to be innocent but I'm happier a BY126 has been fitted on the PCB side.
So, there's no frame lock nor proper line lock. Obviously many components will need replacing which will be attended to in due course.
ID:	168957   Click image for larger version
Old 8th Sep 2018, 3:41 pm   #17
Focus Diode
Responded well to a clean up.
Need to find knobs for it.
ID:	168970   Click image for larger version
Old 9th Sep 2018, 8:18 am   #18
Heatercathodeshort
Heatercathodeshort's Avatar
I've been following this with interest. So what caused the violent fuse blowing? John.
Heatercathodeshort is online now
Old 9th Sep 2018, 10:05 am   #19
Focus Diode
Hi John, I'm not completely sure. On making the tests yesterday I did disconnect the supply to the system switch solenoid, so it could be that.
I want to get the set functioning properly then I'll try reconnecting it.
Cheers,
Brian
Old 9th Sep 2018, 12:25 pm   #20
Focus Diode
Replacing R45 sorted out the none locking timebases. The line hold continues to drift while warming up which should respond to a new 30FL2.
Been able to assess the set further. The CRT isn't brilliant with some misalignment evident on test card. Performance on 625-lines seems OK. Last picture taken on 625.
Much work still to do.
Brian
ID:	169000   Click image for larger version
ID:	169001   Click image for larger version
ID:	169002   Click image for larger version
Copyright ©2002 - 2019, Paul Stenning.
