Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 6th Dec 2017, 2:23 pm   #1
DonaldStott
Default 9-way D-type female connectors
This Request relates to another hi-fi upgrade Project I'm doing.
I'm looking for specific recommendations on where to source 9-way D-type female connectors i.e. not just try eBay or Google.
Thanks in advance.
BVWS Member
DonaldStott is offline
Old 6th Dec 2017, 3:09 pm   #2
camallison
camallison's Avatar
Default Re: 9-way D-type female connectors
Here:
https://www.rapidonline.com/rvfm-ds1...socket-15-0203
No connection other than a happy customer.
Colin
camallison is offline
Old 6th Dec 2017, 3:34 pm   #3
DonaldStott
Thanks Colin for the very quick response.
The link takes me to a chassis mounted connector - I need to attach the connector to the end of a cable so do i just buy a suitable D-type cover or is there an alternative?
BVWS Member
Old 6th Dec 2017, 3:45 pm   #4
Dave Moll
Dave Moll's Avatar
Yes, the same connector is used for chassis mounting and (with a cover) as a line connector. The cover should come with screws for anchoring it to the mating chassis connector (as shown in the entry for part no. 3100-01).
Dave Moll is offline
Old 6th Dec 2017, 3:49 pm   #5
Station X
Station X's Avatar
If it's cables with 9 pin D-type female connectors you're after I may be able to find you some good used ones. I'd need to get them out of the attic and check the gender though.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now
Old 6th Dec 2017, 3:55 pm   #6
DonaldStott
Thanks Dave - Part No. 3100-01 looks ideal.
Thanks Graham - as you'd expect some of the pins need to be linked in a specific way for the Project I'm doing - saves you searching through the attic.
BVWS Member
Old 7th Dec 2017, 12:09 pm   #7
mike_newcomb
Hi Donald, it may help if you provided some photos of what you require to connect to.
Presume you already have the male socket / connector.
How many female ones are required?
Also this could help deciding which cover versions is used and with which locking method.
Regards - Mike
mike_newcomb is offline
Old 7th Dec 2017, 4:52 pm   #8
Pamphonica
Pamphonica's Avatar
Send me a PM - I am sure I have suitable female 9-ways "in stock". Do you need metal or plastic shell?
Jeremy
Jeremy, G8MLK, BVWS Member, BVWTVM Friend.
www.pamphonic.co.uk
Pamphonica is offline
