Reply
Old 5th Dec 2017, 12:39 pm   #1
Telegraph-Hill
Default Garrard Type One Record player on MM cartridge? (Actually a Type A).
Hi there,
just wondering if someone has done a conversion from a Garrard type A to a MM cartridge. I was thinking of an old Sure M75 etc. But maybe there is someone saying... don't try it, not worth, the arm cannot handle MM cartridges. It would save me time than
Greetings from Devon,
Oliver
Telegraph-Hill is offline   Reply With Quote
Old 5th Dec 2017, 12:49 pm   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Garrard Type One Record player on MM cartridge?
Hello Oliver,
Do you mean a Type A?
https://www.vintage-radio.net/forum/...9&postcount=12
If so, I would say that a robust magnetic cartidge would be fine.
N.
Nickthedentist is offline   Reply With Quote
Old 5th Dec 2017, 12:54 pm   #3
Telegraph-Hill
Sorry, of course, I meant type A
Old 5th Dec 2017, 1:15 pm   #4
Andrew2
My thinking is that a nice cartridge like the 75 might be a little delicate for the A. I don't know if you can still find them, but the Shure M3D is a medium compliance cartridge that always seemed to work well with older, heavier mechanisms. Tough as old boots.
Andy G1HBE.
Andrew2 is online now   Reply With Quote
Old 5th Dec 2017, 1:24 pm   #5
Edward Huggins
This is one of the few autochangers you can use a MM in reasonably well. An option to the Shure types might be a Goldring G800 or G850. They were often used in the early Garrard SP25 range.
Edward.
Edward Huggins is offline   Reply With Quote
Old 5th Dec 2017, 1:28 pm   #6
bikerhifinut
If you've got a M75 type2 body I have a spare aftermarket stylus with very little use that I eventually worked out was actually the M75EC type. This is supposed to track at between 2 and 4 grams and I found it did need at least 3 grams to sound clean. If you'd like it then its free to you sir.
PM me if interested.
Andy.
bikerhifinut is offline   Reply With Quote
Old 5th Dec 2017, 1:31 pm   #7
paulsherwin
paulsherwin's Avatar
An Audio Technica AT91 would be a good match and isn't expensive.
paulsherwin is online now   Reply With Quote
Old 5th Dec 2017, 2:02 pm   #8
Telegraph-Hill
Default Re: Garrard Type One Record player on MM cartridge? (Actually a Type A).
You are all Stars Many thanks for all the advise. I just bought a NOS Goldring G800. If this works fine I will also try out the AT91 Audio Technica. They are really not that expensive.
Cheers,
Oliver
Old 5th Dec 2017, 2:15 pm   #9
paulsherwin
The G800 and AT91 are very similar cartridges. There isn't much point in getting both of them!
Old 5th Dec 2017, 8:46 pm   #10
dseymo1
There seems to be a strong market for the M3D these days (perhaps justified - it's a rather nice cartridge, quite apart from being the first 'modern' MM), so finding one at a reasonable price might be difficult.
dseymo1 is offline   Reply With Quote
Old 5th Dec 2017, 11:24 pm   #11
Tom_I
Tom_I's Avatar
Another possibility would be an Audio Technica 3600L, intended for "legacy" decks. Pretty tough, with a carbon fibre cantilever, and not expensive. Tracks at 2.5 to 3.5 grams, but would probably cope with a bit higher.
I'm currently using one in a Garrard AT60 autochanger, and it seems to work very well.
Tom_I is offline   Reply With Quote
Old 8th Dec 2017, 7:21 am   #12
GP49000
Garrard Type A in good condition works very well with magnetic cartridges tracking at around 2.5 grams and up. The calibration of the tracking weight adjustment on the early ones only went down to 3 grams; the Type A Mk II calibration went down to 2 grams but there was no other change to the tonearm or the auto trip mechanism.
GP49000 is offline   Reply With Quote
Old 14th Dec 2017, 3:40 pm   #13
Telegraph-Hill
Just a quick feedback, I tried a "cheap" Audio Technica AT 95 and the Goldring G800. I'm really happy with the Goldring. Even listeners to my show have been impressed with the sound from a nearly 60th years old Garrard. Many thanks for all the advice.
Oliver
Reply
