Reply
Old 4th Dec 2017, 2:04 pm   #1
neil24-7
Default Tesla Talisman 306u & 308u some measurements needed please
Does anyone have a Tesla Talisman they could take a few measurements from please, I need largest width and height measurments on the rear panel of models 306U and 308U, very much appreciated if someone can.
Cheers Neil
ID:	153342   Click image for larger version
neil24-7 is offline   Reply With Quote
Old 4th Dec 2017, 11:48 pm   #2
Stuart R
Stuart R's Avatar
Default Re: Tesla Talisman 306u & 308u some measurements needed please
Rushed upstairs to help, as the back looked familiar, but turned out to be a very different 304U on my shelf. Sorry.
SR
Stuart R is offline   Reply With Quote
Old 5th Dec 2017, 12:28 pm   #3
Norman Raeburn
Hi Neil, The dimensions on my 308 are height 170mm and width 297mm. Hope this helps. Norman
Norman Raeburn is offline   Reply With Quote
Old 5th Dec 2017, 2:54 pm   #4
neil24-7
Many thanks Stuart if I find a decent flat picture or scan I'll get the measurements off you as that will be another to the list.
Norman that's great thank you so much for that, that's another off the list.
I'm now trawling the net for flat images of panels as I find it easier and less hassle to ask for measurements instead of full scans, it's just as easy to work from a picture and the dimensions.
Cheers Neil
Old 17th Mar 2018, 12:32 pm   #5
neil24-7
Thought I would bump this, I'm still after width and height of the 306u if anyone has this model please.
I'm also after measurments for round Ekcos and Philco models including the 444 but I'll put this on another post when I get to them.
Cheers Neil
Old 17th Mar 2018, 12:42 pm   #6
Station X
Station X's Avatar
I'll do the Ecko AD65 for you.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now   Reply With Quote
Old 17th Mar 2018, 1:13 pm   #7
vinrads
Hi Neil picture of 306u with home made back cover 255mm x 150mm at max if you want I can send you a template via post .Mick.
vinrads is offline   Reply With Quote
Old 17th Mar 2018, 2:49 pm   #8
neil24-7
Many thanks Graham, i have a picture that i can manipulate with a program i found on the net, all i will really need is the width and height, hang fire for now and i'll do some drawings of the panels i'm after and put on a new post.
Mick thats perfect thank you so much, i'll use the template i have and the sizes you have given to make a panel, can i send you one when cut.
Cheers Neil
Old 17th Mar 2018, 5:44 pm   #9
vinrads
Hi Neil that would be fine, I suppose you need to check on an actual radio ,let me know when. I will let you have my address , regards Mick.
Old 17th Mar 2018, 6:29 pm   #10
neil24-7
PM sent
Old 17th Mar 2018, 6:40 pm   #11
neil24-7
They cut very well, lets hope they fit, will be looking for someone who needs a 308u panel so will post that in the right place.
ID:	159403   Click image for larger version
Old 17th Mar 2018, 8:06 pm   #12
vinrads
P.M sent regarding the 308u Mick.
Reply
