Old 3rd Dec 2017, 9:01 pm   #1
Goldieoldie
Default Using a grommet as a gear !
Hi
I thought u would share this with you
I was repairing a small transistor radio where one of the tuning gears had fallen apart
Not have a suitable gear ( it fitted on a 6mm splined shaft ) I cut a gromet in halve and positioned it so it engaged with the cog driving the cap
Although It was a tight fit on the shaft I added some evo stick to hold it in place
It works a treat ! It's even started to cut its own teeth into the gromet
Prob won't last for ever but has restored an old radio to working condition which I think is what our hobby is all about
Cheers Pete
Goldieoldie is offline
Old 3rd Dec 2017, 9:39 pm   #2
Reelman
Reelman's Avatar
Default Re: Using a gromet as a gear !
Nice!
Getting it working is what it is all about, sometimes a bodge is the only way to achieve it.
I wonder if I could do the same for the 70’s Grundig cassette mechanisms...
Peter
Reelman is offline
Old 4th Dec 2017, 6:54 pm   #3
slidertogrid
Ingenious ! I have a 1950's clockwork toy with a stripped gear. I will give this a try!
Rich.
You can't turn back the clock..... But you can wind it up again !
slidertogrid is offline
Old 4th Dec 2017, 7:18 pm   #4
G6Tanuki
G6Tanuki's Avatar
I like it! Very much in the "make do and mend" spirit.
In the past I did something similar to replace a gear by making up two SRBP 'cheeks' to fit on the spindle and packing the gap between them with Milliput, then coating the other gear with Vaseline and using slow rotation to cut teeth in the Milliput as it hardened.
G6Tanuki is offline
Old 4th Dec 2017, 9:16 pm   #5
Lloyd 1985
Lloyd 1985's Avatar
Nice!
I used heat shrink in a Sony cassette deck on a gear that engages the heads during playback, the gear was made of a plastic that had the consistency of a lump of hard cheese! It stripped itself when I first tried it out, heat shrink gave it just enough grip to make it work.
Regards,
Lloyd
Lloyd 1985 is offline
Old 5th Dec 2017, 4:22 pm   #6
camtechman
camtechman's Avatar
Reelman,
I've got an odd sheet of firm rubber, about the thickness of the Grundig gear, can't remember where I got it from but now, encouraged by Goldieoldie's success, I'm going to experiment with making "That Gear".
Will report later, I'm even going to order some more No11 blades for my Swann Morton scalpel (and some Band-Aids for my fingers !)
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 5th Dec 2017, 9:39 pm   #7
dseymo1
Perhaps traditional rubber tap washers could be pressed into similar service.
dseymo1 is online now
Old 5th Dec 2017, 9:43 pm   #8
Karen O
Karen O's Avatar
I once made a makeshift slow motion control that used a grommet pressing against a metal tuning dial.
Karen O
Humans have a special purpose in the cosmos: to rid the universe of anthropocentricism!
Karen O is offline
Old 6th Dec 2017, 2:33 pm   #9
deliverance
Simple but effective nice one
deliverance is offline
Old 7th Dec 2017, 4:20 pm   #10
Nymrod121
Nymrod121's Avatar
Brilliant!
The BBC Audio Test Set EP14/1 in all variants has a similar arrangement for the frequency set control. A (flywheel-equipped) spindle has a rubber grommet that presses against the surface of an aluminium disc connected to the Wien Bridge oscillator's air-spaced capacitor. It serves as a 'mitre box' * and reduction gear combined.
Guy
* (any bus enthusiasts out there will know this is a 'Bristol VRT transmission' term )
"No-one's ever complained before!"
"Are they Americans?"
(Joyce Grenfell/Edie Martin: "Genevieve")
Nymrod121 is offline
Old 8th Dec 2017, 12:10 am   #11
Argus25
Argus25's Avatar
Default Re: Using a grommet as a gear !
Good repair if you are stuck on a space ship or on moon base alpha with no spares and very few tools, the ingenuity might save the day.
Many tuning mechanisms that have gears rather than some sort of friction drive did it because the vanes of the variable capacitor required to have some fixed registration with the tuning dial-knob or tuning pointer (I'm not sure if this is so in your radio). In these cases it is necessary to replace or re-manufacture the missing gear if the dial-station pointer system is to work properly.
Old clocks, electric or mechanical, can be a good source of small gear wheels to jimmy up a repair, if a gear set is required. In the days of watch & clock making the local repairer would machine one up for a good price, but those days appear long gone.
Argus25 is offline
Old 8th Dec 2017, 3:41 pm   #12
Lloyd 1985
Lloyd 1985's Avatar
I'm hoping that decent quality 3D printing will eventually become as affordable as photo printing is now, I've measured up the gear that I need for the Sony cassette deck, just need to be able to manufacture a good replacement! Strangely, on a slightly later Mk2 version of the deck that particular gear had been done away with and replaced by 2 wheels with belts instead. I guess it was probably a problematic part for Sony, so they redesigned it.
Regards,
Lloyd
Old 10th Dec 2017, 8:15 am   #13
FrankB
I have used neoprene fuel line to replace the rubber friction drive on the tuning shaft of an Atwater Kent model 55. Last I heard, it was still working , and that was 15 years back.
Using rubber as a "friction slip drive" was common in a few U.S. made radios.
Some were odd cast parts, and a real pain to replace or repair so they worked reliably.
I honestly had forgotten about using a grommet. Thanks for the reminder!
FrankB is offline
