Old 1st Dec 2017, 10:49 am   #1
Argus25
Argus25's Avatar
Default 1937 RCA Projection TV "gun"
I recently found this in some of my archived magazines. It is amazing how far advanced RCA were with this technology at the time. The final anode voltage on the especially made CRT in this "gun" was 10kv. The construction is certainly very futuristic for the time, building it into the cylinder to make it like a gun.
When did the first projection sets turn up in the UK ?
ID:	153202   Click image for larger version
Argus25 is offline
Old 1st Dec 2017, 11:43 am   #2
Peter.N.
Default Re: 1937 RCA Projection TV "gun"
Looks a lot better than the Philips and Decca systems from the '50s and they used 25 kv.
Peter
Peter.N. is offline
Old 1st Dec 2017, 12:15 pm   #3
Nuvistor
Nuvistor's Avatar
European 1950ís projection TVís
https://www.radiomuseum.org/forum/pr...sion_sets.html
Slightly bigger version of the 1937 type.
Frank
Nuvistor is online now
Old 1st Dec 2017, 12:35 pm   #4
peter_scott
peter_scott's Avatar
My parents' Philips was poor because it lacked dc restoration but I must say I was impressed by Trevor Goodenough's Decca 1000 projecting an image equally as large as the RCA image.
Peter
Name:	P1010925a (Medium).jpg
peter_scott is offline
Old 1st Dec 2017, 4:08 pm   #5
Dave Moll
Dave Moll's Avatar
This displayed picture on the second page of the article doesn't look quite right to me. If you look carefully at the shadow of Dr Law's head, the outline of the model's shoulder continues as a darker shadow. Methinks this was a printed picture being simply illuminated by a light being shone on it.
Dave Moll is offline
Old 1st Dec 2017, 4:45 pm   #6
Argus25
Argus25's Avatar
Wow, that one looks massive.
I found a little more information on the 1937 gun version in Fink's television book. The CRT apparently runs 2mA beam current and they mention a figure of 5mA too and 10kV, so it has about 20 to 50 watts screen power. No a wonder the CRT phosphors had a habit of aging relatively quickly. It also has a focus coil wound to prevent spherical aberration. I'm sure a scan collapse on one of those projection CRTs would destroy the phosphor is short order.
Argus25 is offline
Old 1st Dec 2017, 6:08 pm   #7
G6Tanuki
G6Tanuki's Avatar
Fascinating.... also remember the mechanically-scanned projection TVs of the same era: Scophony being the most well-known example:
https://blog.scienceandmediamuseum.o...scanner-motor/
G6Tanuki is online now
Old 1st Dec 2017, 9:02 pm   #8
rambo1152
rambo1152's Avatar
I have heard it said of Eidophor projectors, that by rights they shouldn't really work at all!
Graham.
G3ZVT
rambo1152 is offline
Old 1st Dec 2017, 9:12 pm   #9
rambo1152
rambo1152's Avatar
A business acquaintance of my dad had a colour CRT projection TV in his lounge. The screen was integral to the set like a RPTV, but it was front projection with the tubes mounted in a trough at the front.
Impressive for the mid '70s.
I can't recall the make or model, but I suspect I am about to be told
Graham.
G3ZVT
Old 1st Dec 2017, 10:53 pm   #10
peter_scott
Perhaps: Sony Videoscope KP-5040 1981 50"
https://www.youtube.com/watch?v=Pm0oLFr0j2s
Peter
Old 1st Dec 2017, 11:08 pm   #11
turretslug
Some flying spot telecine scanners had air-blast cooling on the CRT face- I wonder if this was ever used on projection sets, or maybe the noise would have been too obtrusive in a viewing/listening environment.
turretslug is offline
Old 2nd Dec 2017, 2:14 am   #12
emeritus
In a film which features the original low definition pre-war German TV system
https://www.youtube.com/watch?v=0oqJBVg7MxI
at 5:20 there is a short scene showing what seems to be a projected live TV image. No details given, but at that time the Germans did develop an intermediate film system for projecting live TV that used a conventional movie projector to produce the image.
Attached is leaflet describing Decca's large screen projection TV from 1954. I wonder what the life of its tube was?
emeritus is offline
Old 2nd Dec 2017, 9:21 am   #13
Peter.N.
The Philips set had an elaborate protection circuit should a timebase fail, the problem was you had to somehow overcome it to fault find. Yes I can confirm that a time base collapse without the protection system will destroy the screen phosphor instantly.
Peter
Peter.N. is offline
Old 2nd Dec 2017, 9:56 am   #14
Heatercathodeshort
Heatercathodeshort's Avatar
Tube life was actually very good. The problems arose when one of the timebases failed and the protection circuit had an unknown fault.
This was quite rare but most engineers fitted an old burnt screen tube [Mullard MW6-2] for chassis fault finding and when all was working ok the good tube was refitted.
I have a number of projection receivers. I brought this beast back to life for the Dulwich museum. John.
https://www.vintage-radio.net/forum/...d.php?t=120026
Heatercathodeshort is offline
Old 2nd Dec 2017, 10:39 am   #15
peter_scott
I think that Telefunken Karolus system was actually a filament lamp matrix display rather than a projection system.
http://www.sarganserland-walensee.ch...kow/nipkow.htm
Peter
Old 2nd Dec 2017, 11:29 am   #16
vidjoman
I’ve seen the Eidophor projectors in use around 1980. They were very large and gave brilliant pictures fed from 2” video tape. The screen used was a cinema type about 30 feet across.
I worked for a dealer that sold the Sony projectors at that time and they cost about £7000. The Eidorphor was about £200,000. So not going to be a domestic product, plus you would need a spare room to house the projector and it’s associated equipment.
vidjoman is offline
Old 2nd Dec 2017, 11:45 am   #17
Dave Moll
Dave Moll's Avatar
The Philips set had an elaborate protection circuit should a timebase fail... Yes I can confirm that a time base collapse without the protection system will destroy the screen phosphor instantly.
Peter
The Decca also has this feature - for the same reason.
Old 2nd Dec 2017, 2:05 pm   #18
emeritus
Thanks for the link to the Karolus display, most interesting. I had wondered if the lack of flicker that you usually see when a TV appears in shot in a cine film, meant that the picture was produced by special effects. The persistence of filament lamps could account for the the lack of flicker, meaning that it was indeed a straight shot of a Karolus display.
emeritus is offline
