Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 29th Nov 2017, 5:01 pm   #1
kevinb
kevinb's Avatar
Default PX25 Valve
I have one of these un boxed I am told it may be worth a bit if its in good condition, problem is I don't know.
does anyone out there within reasonable distance from Leicester have facilities to test this valve.
Regards Kevin
kevinb is offline
Old 29th Nov 2017, 10:27 pm   #2
Brian4radio
Brian4radio's Avatar
Default Re: PX25 Valve
Hi Kevin, well I have a working Taylor 45C valve tester so could test your PX25 valve. Its not the most sophisticated tester but it can check for filament continuity, element shorts, cathode leakage and most of all the mutual conductance of the valve. I have tested PX25 valves on this tester. I live in Tamworth and visit Hinckley on a regular basis so not too far away. regards Brian.
Brian4radio is offline
Old 15th Dec 2017, 9:11 pm   #3
Brian4radio
Hi team, valves now tested so can you please remove this post. Regards Brian
