Old 28th Nov 2017, 10:10 pm   #1
Station X
Station X's Avatar
Default Does anyone know what this is?
This came from my late father's workshop and is in good clean condition which suggests he used it. The question is what for?
It would appear that the round base plate is designed to fix to a bench or wall and then a work piece of some kind is clamped to it using the wing nut.
Does anyone know what its function was?
Thanks.
ID:	153073   Click image for larger version
ID:	153074   Click image for larger version
Graham. Forum Moderator
Station X is offline
Old 28th Nov 2017, 10:50 pm   #2
ms660
ms660's Avatar
Default Re: Does anyone know what this is?
Pot shot...Old magnifier stand...bench...wall...machine?
Lawrence.
ms660 is offline
Old 28th Nov 2017, 11:02 pm   #3
Radio_Dave
Radio_Dave's Avatar
I used to work in the shoe industry and It looks like the base of an industrial sewing machine lamp to me.
Radio_Dave is offline
Old 28th Nov 2017, 11:05 pm   #4
Station X
Station X's Avatar
That's certainly very likely, as Dad lived in Norwich all his life, although he didn't work in the Boot and Shoe Industry.
Old 28th Nov 2017, 11:06 pm   #5
ms660
ms660's Avatar
Spot on me thinks:
https://www.worthpoint.com/worthoped...ing-1724157767
Lawrence.
ms660 is offline
Old 28th Nov 2017, 11:15 pm   #6
Radio_Dave
Radio_Dave's Avatar
I've found a picture https://i.pinimg.com/originals/5f/0a...2a8fa00805.jpg .
Old 28th Nov 2017, 11:18 pm   #7
Station X
Station X's Avatar
The forums come up trumps again!
Thanks guys.
I'm pretty sure I don't have the rest of it, but I'll have a look.
Old 29th Nov 2017, 1:58 am   #8
broadgage
Of course your late father may have used it for some other purpose.
I have seen a very similar stand used to hold a Bunsen burner for evenly heating an article being rotated on a turntable.
(for the purpose of soldering a brass container, the heat had to be even around the circumference)
broadgage is online now
Old 29th Nov 2017, 9:44 am   #9
M0FYA Andy
I totally agree, my late father was the maintenance engineer in a hosiery factory with lots of knitting and sewing machines. As a result I had two of these lamps on my electronics bench as a schoolboy back in the 60's. They were fitted with 6 volt bulbs supplied by a transformer hanging on the wall. I might even still have them in 'deep storage' somewhere!
Andy
M0FYA Andy is offline
Old 29th Nov 2017, 5:42 pm   #10
broadgage
The bulbs most commonly used for these sewing machine lights were frosted reflector lamps, screw base, 12 volt, 17 watt.
6 volt versions were also used, again 17 watts.
The 6 volt or 12 volt supply was often obtained from a tapping* on the motor and therefore not as safe* as it sounds since there was no isolation from the mains.
The 12 volt 17 watt bulbs are still available, and before the LED age were used for other purposes when a directional but not highly focussed light was required from a 12 volt supply.
*I used to work for the maintenance contractor at a large department store that had a tailoring alterations and repairs department.
The factory inspector criticised the lighting on the sewing machines, and I was given the job of retrofitting proper isolating transformers to supply the 12 volt lights.
Old 29th Nov 2017, 7:57 pm   #11
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
I was under the impression that Northamptonshire was where the "Boot and Shoe" industry was based. Isn't Norwich in Norfolk?
Colin.
ColinTheAmpMan1 is offline
Old 29th Nov 2017, 8:12 pm   #12
M0FYA Andy
The bulbs used in my two examples were certainly not frosted reflector lamps with a screw base. They were small bayonet types, with the reflector as a separate item, part of the lamp.
Andy
Old 29th Nov 2017, 8:26 pm   #13
Station X
Station X's Avatar
Colin.
Yes. Norwich is in Norfolk. It was well known for producing Ladies and children's shoes. I can think of at least a dozen shoe factories there.
Old 29th Nov 2017, 10:02 pm   #14
Herald1360
Herald1360's Avatar
I want one!
It's steampunk without even trying!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 29th Nov 2017, 10:24 pm   #15
Oldcodger
Colin.
I seem to remember that the boot & shoe industry was nationwide ( certainly from I picked up from my late father, who was in the trade for years, as a master shoemaker).
Oldcodger is offline
Old 29th Nov 2017, 10:39 pm   #16
Station X
Station X's Avatar
When asked what their job was people in Norwich would often say that they were "in the boot work". Many of them burned redundant shoe lasts on their open fires.
The National Union of Boot and Shoe Operatives (NUBSO) had their headquarters, or possibly a sizeable branch office in Norwich.
The other big centre apart from Northampton and Norwich was Leicester.
Old 29th Nov 2017, 10:41 pm   #17
Station X
Station X's Avatar
Originally Posted by Herald1360 View Post
I want one!
If it's just the stand you want you're welcome to it FOC.
Old 30th Nov 2017, 12:15 am   #18
Oldcodger
I do remember the old lasts, which were made of wood, but when I cleared out late dad's shed with what was left of his collection of lasts ( all metal), I'd have needed at least a 7.5-ton truck to take them away.
Old 30th Nov 2017, 12:50 pm   #19
frankmcvey
It looks akin to a modern "third hand" - perhaps your father used it as such!
Cheers,
Frank
frankmcvey is offline
Old 30th Nov 2017, 6:41 pm   #20
Herald1360
Herald1360's Avatar
I want one!
No, it was the whole thing.
The stand offer is tempting, but I'd probably never get round to making the rest. Maybe one of our more mechanically proficient members would take up the challenge?
....__________
