28th Nov 2017, 11:44 pm | #21 | |
Re: SMDs and stripboard
I have really poor vision in one eye, effectively monocular, and I haven't yet tried working with SMD's and suspect it will prove quite difficult! B
29th Nov 2017, 9:03 am | #22 |
Chemtronics stuff has a very long shelf life (years). Some of the cheap stuff is hygroscopic so keep it in a zip lock bag and it’ll last longer. To be honest I’m getting through a roll a month at the moment (thanks Tektronix! ) so it doesn’t hang around.
29th Nov 2017, 10:41 am | #23 |
I find the Servisol braid is still OK after several months too.
As for the copper wire wrapped round the iron, it's great for melting wax into woodworm holes but not much else in my experience. Nick. |
29th Nov 2017, 10:52 am | #24 |
Being a 19" rack man, I long ago decided that SMD's were only suitable for watchmakers!
29th Nov 2017, 11:14 am | #25 |
I must admit to being surprised at how tiny they were, despite having read the specs and seen lots of SOT23 devices in commercial products. They look bigger fitted to PCBs, presumably because of the pads and solder.
29th Nov 2017, 12:58 pm | #26 |
Liquid flux makes soldering these tiny packages a lot easier. A fine bent 45 degree tip also helps. If the device is glued down, the pins flooded as described, a sharp tap on the bench gets rid of excess solder. This is how they do it on the assembly lines for individually installed IC's like FPGA's etc.
Andy.
29th Nov 2017, 2:45 pm | #27 |
I wouldn't tap it on the bench to get rid of solder. That solder doesn't always end up where you expect and turns up between the pins on a TSSOP package for example. This, when it is a switching converter, is followed by a miniature firework display. I speak from experience
If that is being done on assembly lines, they should be shot. Glue, then drag solder, then use wick to get rid of the excess, then clean, then inspect. |
