Reply
Old 27th Nov 2017, 4:54 pm   #1
GrimJosef
Default How much current should a Marconi DER valve pass ?
I have had a Marconi DER (Dull Emitter Receiving) valve for quite a few years now. It looks very much like this http://www.r-type.org/exhib/aab0001.htm except that the bright silver getter covers the top half of the glass envelope and it doesn't have a paper label wrapped around the base. There is a BBC stamp of the 'Postmaster General' type on it which, apparently, dates it to 1922-24 http://g3ynh.info/valves/old/BBC/BBC.html#GPO. The valve's serial number is, I think, K1135. As well as the letters D.E.R. there's also a faint 'Marconi Valve' stamp on the glass.
Today I finally tried it out. At 1.8VDC the filament draws 375mA or so. I bridged the filament with a pair of 47ohm resistors in series and applied DC HT between their junction and the anode, and negative grid bias between the same junction and, yes, the grid. Attached are a couple of plots of anode current in mA, first versus grid voltage with 75V HT between anode and filament and second versus HT voltage with the grid at -1.00V, again relative to the filament. The third picture is a scruffy phone snap of the little fella in my scruffy lashed-up test rig.
With just a milliamp or two of anode current I'm guessing that this valve is a bit tired. I can't seem to track down a data sheet for the DER but I'm sure there are those here who know what the current really should be and so can tell me just how tired. In any case it's a lovely thing to look at given its utter simplicity and considerable age.
Thanks in advance !
Cheers,
GJ
Name:	Marconi DER Ia vs Vg 75Vak.jpg
ID:	152967   Click image for larger version
Name:	Marconi DER Ia vs Vak -1.0Vg.jpg
ID:	152968   Click image for larger version
Name:	DER valve on test cropped small.jpg
http://www.ampregen.com
GrimJosef is offline   Reply With Quote
Old 27th Nov 2017, 5:54 pm   #2
ms660
ms660's Avatar
Default Re: How much current should a Marconi DER valve pass ?
W.W....Marconi-Osram D.E.R valve test (includes curves) W.W. August 1924 mag. pages 631 & 632:
http://www.americanradiohistory.com/...4-08-S-OCR.pdf
Lawrence.
ms660 is online now   Reply With Quote
Old 27th Nov 2017, 6:29 pm   #3
GrimJosef
Thanks very much for that Lawrence.
I went back out to the workshop, raised the filament voltage to the full 2.0V, grounded the grid and took the HT up to 80V. The graph in W.W. (their Fig 2) says that you'd expect about 2.7mA under those conditions. I measured 2.44mA so my valve is actually running at 90% of theirs, which is very pleasing after rather more than 90 years !
Cheers,
GJ
Old 27th Nov 2017, 6:33 pm   #4
ms660
ms660's Avatar
No problem, took a few searches but got there.
Lawrence.
Old 28th Nov 2017, 12:27 pm   #5
Herald1360
Herald1360's Avatar
Sounds like the comment about long life in the WW article was justified, then!
A bit further on there's a description of a technique for replacing the filament in one of the horizontal anode type triodes!
.........._______
.....___/|__|__|\____
.=.( _---\__|___|_---_)
.........O...Chris....O
Herald1360 is online now   Reply With Quote
Reply
