Old 26th Nov 2017, 4:34 am   #1
Otari5050
Otari5050's Avatar
Default Unusual deposit in tube (valve)
Hi folks, got a nice KT88 tube (NOS) which has an unusual white deposit on the inside of the glass.
At first I thought it had gone to air, but the getter is perfect and a check on an AVO MK4 shows it's in perfect health, no gas at all.
Sorry the photo isn't the best but it's hard to get close.
You can see where it's white from the base up, but then goes clear before the bend in the glass.
I've never seen this before in a tube.
I'd like to get others' thoughts on this.
Otari5050 is offline
Old 26th Nov 2017, 9:28 am   #2
Peter.N.
Default Re: Unusual deposit in tube (valve)
I have occasionally seen white deposits on the inside of a valve and thought the same as you but if the heater lights up and it works OK I wouldn't worry about it.
Peter
Peter.N. is offline
Old 26th Nov 2017, 7:54 pm   #3
high_vacuum_house
high_vacuum_house's Avatar
Location: Rugby (home) and all over the country for work
Smile Re: Unusual deposit in tube (valve)
Probably just a peculiarity caused during manufacture. I think that the white is where the gas jets would have been melting the glass and a tool being used to form the joint between the pinch electrode assembly and the glass bulb itself.
I have seen valves with white patches around the base and funny coloured getters but are all fine. Some clean B9a valves have quite powdery white looking bases inside.
Could be the glass to base cement but this is usually much darker and rougher.
Christopher Capener
A proper radio is one that needs to be moved with a wheelbarrow !!
high_vacuum_house is offline
Old 28th Nov 2017, 9:49 am   #4
ionburn
ionburn's Avatar
I noticed with a NOS valve the other day that there seemed to be a white milkiness in the glass itself around the base which was not present in other examples of the same valve. It was otherwise identical to others of the same type.
ionburn is offline
Old 28th Nov 2017, 10:27 am   #5
Sideband
Sideband's Avatar
More than likely a colouration of the glass itself. If it checks out perfectly just use it and enjoy!
'And, in the end, the love you take is equal to the love you make'
The Beatles.
Sideband is offline
Old 28th Nov 2017, 1:26 pm   #6
Boater Sam
Boater Sam's Avatar
Overheating of soda glass in the blowing/moulding process can be the cause. Normally re-annealing would remove the whiteness.
Boater Sam.
BVWS Member
Boater Sam is offline
